turbo psi
Old Feb 19, 2008 | 09:45 PM
strrew's Avatar
turbo psi
is there a problem running 01 turbo without a wastegate line hooked up. produces 40psi
Old Feb 20, 2008 | 07:38 PM
dalee's Avatar
boost
from other posts i think your on the edge. I think they say 44psi and you need studs in the block or you push out the head gasket.
Old Feb 20, 2008 | 07:44 PM
Adam3291's Avatar
Running the risk of that turbo's life being short lived. Most people say not to run the HX35's past 35 psi.
Old Feb 20, 2008 | 07:46 PM
Vern Calhoun's Avatar
I've heard that anything over 35 and your pushin' hot air, something about its out of its functional range. I've seen a compressor wheel that granaded at 50 and its ugly. Fill out your sig. and people can help you more on here.
Vern
Old Feb 20, 2008 | 07:52 PM
2001 CTD's Avatar
i read on cummins website that 30psi max avobe that and u risk turbo failure and engine damage. i got mine sittin at 30-31psi with a custom j-hook that i made works good i find that even anything above 25-27psi doesnt even effect the egts at all and does not make an increase in 0-60 and 1/4 mile times. all times are by the attitude monitor.
38 Cigarette
16
Aug 28, 2015 11:27 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
