Turbo master install
Old Aug 19, 2003 | 11:05 PM
DynamicalyUnstable's Avatar
So I got a Turbo Master and I noticed the instructions say to remove the turbo. This might be a really dumb newbie question but I cannot see how to get the nuts off the bottom of where the housing mounts. Is there a trick or special tool for this? I'm not mechanically declined, it just looks like a real biotch. Also, does anyone know what I need to do to the small tube that goes into the stock actuator once I remove it? Do I just leave the hole in the turbo? Seems nuts but there is no instruction on what to do with that.
Thanks
Old Aug 19, 2003 | 11:15 PM
1dslram's Avatar
Re:Turbo master install
You can get to the bolts with a 15mm box wrench and I have also used a socket and ratchet. You have to go by feel as you know you can't see back there. A flex mirror is a great help, but everything is backwards.
Bruce
Old Aug 20, 2003 | 02:38 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Yep those bolts are a little tough but not impossible. A good step to stand on so you can reach them comfortably helps. I used a short stubby wrench once I broke it loose, much easier to handle behind the manifold. This is a "go by feel" job on the two bottom bolts.
You have to work them out a fraction of a turn at a time, but if you spray them with rust penetrating oil first, they move pretty well. The turbo master comes with a plug to seal off that little hole.
You can go to our tech article section here and see a step by step "How to article" on the turbo Master.
virginiaram
Dec 26, 2012 04:09 PM
AllPlay
Mar 21, 2011 05:47 PM
admin
24
Mar 10, 2003 12:58 AM
Copenhagenjunkie
Feb 2, 2003 10:28 AM
Lary Ellis (Top)
Jan 21, 2003 05:10 PM
