check engine light after ts performance shift master install
Old Dec 21, 2012 | 06:06 PM
virginiaram's Avatar
2007 2500. Just installed the shift master, and upon start up the check engine light came on. The code says throttle valve circuit low. Of course the place is closed so I cannot call and ask them questions. I followed the directions, double and triple checked the connections that I've made. Any ideas as to what is causing the code?
Old Dec 21, 2012 | 11:28 PM
rockcrawler304's Avatar
Did you let it idle for a little while and run it through the gears?
Old Dec 22, 2012 | 01:55 PM
bdewey's Avatar
I have same thing installed on my 07. I had that code pop up once and all it was a loose connection on bottom where it was secured and that connection got wet. I rechecked connections and re-set code and no issues since.
Old Dec 23, 2012 | 05:25 PM
it wouldnt shift out of first gear, and the codes would not clear. I checked the connections and re did them twice. Ended up just taking it back off, and putting it back stock.
Old Dec 26, 2012 | 04:09 PM
atown's Avatar
Been thinking of this mod for awhile. Other than the O.P how do the others feel about this mod? Does it work as advertised?
Thanks
jmerola
Jul 31, 2009 12:15 PM
White97GTVert
22
Apr 4, 2008 07:02 PM
JCLeary
27
Mar 20, 2008 07:38 PM
Dusty Ratcliff
May 24, 2006 10:28 PM
