Turbo advice?
Old May 7, 2008 | 01:00 PM
97dodge12v's Avatar
Turbo advice?
i have a 97 with stock turbo and i was wondering what would be the best thing to do for a new turbo, or maybe different housing? thanks!
Old May 7, 2008 | 01:34 PM
txdodge97's Avatar
what are your mods fill out your signature so everyone can get an idea and let you now.
Old May 7, 2008 | 02:55 PM
97dodge12v's Avatar
Okay Thanks, I Have A #5 Plate And Boost Elbow And Straight Piped
Old May 7, 2008 | 11:30 PM
Mike Holmen's Avatar
The Guru
You running any gauges? Boost and pyro readings would be helpfull. You an automatic or manual?? What gears you got? How you plan to use the truck to do drag racing or hauling stuff? Cost important?
Old May 8, 2008 | 12:05 AM
97dodge12v's Avatar
well i will be towing about 9k pounds every now and then just up to the mountains. i have some guages, just not installed yet. it is a auto and i not sure what gears, whatever stock is what i have. and cost is kind of important to me, i only 19 and still in school... thanks alot!
Old May 8, 2008 | 08:16 AM
ahopper's Avatar
you really want a transmission befor a turbo. trust me on this one. i have the same set up as you. i have 33in tires, auto, 3.54 gears.all i did was turn my pump up and i snapped the input shaft to the tranny. get the guages in and see what your egt temps are first and what you have for boost as well. everything in my sig is on a stock turbo and i have towed 10k up some good long grades with out to much of a problem. i either have to keep it at or above 70mph. if i slow down in over drive you will want to kick it out and you can criuse at 60-65 all day without problems. just watch the temp on the stock trannie. i just had a gps in the truck and my 70 is 76 just to let you know. and my 65 is 69.
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
Ada381
Feb 10, 2008 07:58 AM
ryan466
Aug 30, 2006 10:10 AM
2broke2smoke
45
Jan 26, 2004 03:59 PM
Hawkeye
13
Sep 17, 2003 11:04 AM
