TST or Edge Drag Comp
Old Oct 21, 2007 | 01:27 AM
heavyJ's Avatar
What is the better stack with a Smarty? A TST or an Edge Drag Comp? I've heard that the TST give's you better low end than the Drag Comp when stacked with a Smarty. Has anyone ran both of them in that combo? I have 3.55 gears in my rig so low end is a deffinate issue for me. Thanks Heavy J
Old Oct 21, 2007 | 03:05 AM
HOHN's Avatar
I think the general consensus is that a TST stacks better with a Smarty because you can use the even numbered softwares (with timing). The Drag Comp has it's own timing so you'd have to use the odd numbered (no timing) softwares, which is not preferred. Or so I'm told...
JMO
Old Oct 21, 2007 | 08:33 AM
jazz_kt's Avatar
I like the drag comp better than the tst. I have them both right now and keep switching back and forth.I use the drag comp on ez mode with the smarty and tst. which is a nice combo too. Everyone brags about the timing of the smarty but to tell you the truth I think the comp's timing is just as good. And the smarty settings (even # no timing odd #'s timing)
Old Oct 21, 2007 | 09:02 AM
J Lent's Avatar
Last year at Reedsville a guy dynoed his truck running the TST & then he dynoed with Drag comp later. He also stacked the 2, but His best numbers were with the Drag Comp only & the powerband was way smoother. I love my Drag/Smarty stack, but I haven't tried the TST/Smarty to compare.
Old Oct 21, 2007 | 09:47 AM
heavyJ's Avatar
well thanks for the input I really think that there both just as good from what I'm hearing and maybe Just have to play around with them in the future.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
66fordcrewcab
34
Jun 22, 2007 07:43 PM
rockjeep73
Mar 25, 2005 03:34 AM
