Truck wont rev past 2500? wierd!
Old Aug 25, 2007 | 05:34 PM
mike_ward's Avatar
I just 100 plated my 96 and it pulls allrigt to 2200 thin falls on its face.
It revs to 2500 and stays there for about 2 secs before it shifts. I dont get it.
IT did the same thing before i plated it.
Its it the gov?? adj? washer mod?
Tranny is brand new~
Old Aug 25, 2007 | 06:28 PM
nirion's Avatar
You need some 3k GSK (3000 rpm governor spring kit). The will allow it to rev freely to 3000 RPMs. They also make a 4k GSK.
Old Aug 25, 2007 | 06:52 PM
kelownadiesel's Avatar
yep you wont be truly impressed until you add the gsk.Keep in mind if you do the 4k kit you must upgrade the valve springs as well.get guages asap!
Old Aug 25, 2007 | 10:32 PM
Ramdriver15's Avatar
in an auto you can get away with the 4kgsk with no valve springs. The tranny will shift way before you hit 4000rpm. Unless you polan on making them squireels run that fast all the time.
Old Aug 25, 2007 | 11:02 PM
mike_ward's Avatar
Im not real excited about 4k rpm on my truck, scares me)
I thank im going to do the 3k washer mod. Im still searching for some good pics to under stand it a little more before i tear in to it.
My other problem is that it takes forever to shift, it just hangs out @ 2500 rpm would the 3k make it shift like normal
Old Aug 25, 2007 | 11:06 PM
yep it really helps it getting into overdrive.thats what I found anyways
Old Aug 26, 2007 | 08:29 AM
mike_ward's Avatar
what i ment was if im wide open throttle, It takes forever to shift,
If i stomp it and let her wind up to aabout 2300 and let off it for a split sec. and stomp it again i can get it to shift like that. If not it literly takes like 2-3 secs for the ***** to shift.
Old Aug 26, 2007 | 03:45 PM
it will allow you to rev out the truck My 96 did the same thing and with the 3kgsk i found it helped trmendously. Noi have a lot of workdone to the truck and i have zero complaints except the converter slips and the trany shutters a litle.
Old Aug 26, 2007 | 04:33 PM
mike_ward's Avatar
My tranny was rebuilt 4 k ago, i broke it in right.
It has hevy duty tq verter, and bands. it has a huge oil pan on it also.
dont know much more than that
Old Aug 27, 2007 | 11:20 AM
put a washer mod 3 kgsk in it. You will love it. This mod is real easy...... i did it on my truck, it is pretty sweet.....
Old Aug 27, 2007 | 04:49 PM
mike_ward's Avatar
ram driver, any pics of the install?? im ready to do it i just not 100% i totaly understand how. what, where and how.
Old Aug 27, 2007 | 05:53 PM
Muddin_dude06's Avatar
You most likely need to adjust your govenor arm, it is probably falling underneith the plate.
kujo
Dec 7, 2010 07:48 PM
RichN
Mar 9, 2010 05:49 PM
mainer
Oct 13, 2008 06:24 PM
eeddie30
Aug 28, 2006 10:38 PM
chadpatten
27
Nov 30, 2005 10:31 AM
