triple disk or single convertor
Old Jan 22, 2009 | 08:45 PM
1badchopper's Avatar
Im going thru my trans.Is the triple disk worth the extra money.
Old Jan 22, 2009 | 10:02 PM
j-fox's Avatar
If it is built right ( there is no other way) , a single is all most need. The multi-disc converters are responsible for many broken input shafts. But, follow the advice of the trans builder.
Old Jan 22, 2009 | 10:21 PM
67HotRod's Avatar
I agree with j-fox. Talk to your trans builder. I was going to go for the triple disc, but dave goerend said I would hate it for the setup I have. Very happy with my single disc!
Old Jan 23, 2009 | 02:36 AM
wcbcruzer's Avatar
In my opinion, stick with a single disc until you exceed its horsepower levels and need a triple disc. You have to be careful where you get a triple disc converter from. They're not all made the same.
Old Jan 23, 2009 | 03:55 AM
AlpineRAM's Avatar
I think you should be concerned much more with the fluid coupling characteristics of the TC than with the method of lockup.
As long as the lockup clutch holds the torque it's the same whether it has one or 10 disks.
The fluid coupling is what gets you rolling etc. So if you have the wrong setup there (it needs to be matched to your engine mods, tire size, axle ratio etc) you will not be happy with it until you reach lockup speed.
Just my 2c
AlpineRAM
Old Jan 23, 2009 | 07:15 AM
What lock up speed should I look for.
Old Jan 23, 2009 | 08:55 AM
dzlfarmboy's Avatar
Under 500hp go with a single disc. I thought thats all I would ever need but I did eventually fry one, but that was with 790hp Spraying. Just make sure you get one with good fluid coupling.
Old Jan 23, 2009 | 10:19 AM
Crazydave's Avatar
Depends what your what to do, (sled pull, drag race) and what size turbo you have (were it spools)
Old Jan 23, 2009 | 02:04 PM
Light towing,racing around towns.I do have the ATS 3000 turbo.And adrenaline with 150hp sticks
Old Jan 23, 2009 | 05:41 PM
AlpineRAM's Avatar
Which tire size and which axle ratio?
A lot of aftermarket converters do lower the stall point (which is good) but some offer more torque multiplication in your setup's sweet spot.
So the phone calls to the different vendors are money and time well spent. If a vendor tells you that he has the best TC for all setups.... take it with a grain of salt.
I haven't shopped for TCs for some years now so I can't say which vendor is good now, I still have my DTT and am really content with it. (It matches my driving style, my roads and my engine mods)
HTH
AlpineRAM
Old Jan 27, 2009 | 09:17 AM
hic316's Avatar
I have a protorque billet single disc and I love it.
1985cucv
16
Aug 19, 2009 05:02 PM
winkdemon
Aug 3, 2009 04:13 PM
dodge_24
13
Jul 12, 2009 08:55 PM
cconrad331
Jan 27, 2008 09:47 AM
DSjockey
34
Jul 20, 2007 07:03 PM
