triple disk dtt tc
triple disk dtt tc
Is anyone out there running a triple disk dtt torque converter. My builder james was ordering my parts and bill at dtt recommended I go with a triple disk. This is the first time I've really heard them recommend it. Bill recommends it because of my horsepower and the occasional time I tow my backhoe or little dozer. Is anyone running it. Is anyone running a single disk with high horsepower and heavy towing and how is it holding up. There is minimal cost difference, but I don't know the advantages and disadvantage. Will there be a difference in speed or power. Thanks for the help.
I put in a chip set to increase my HP and torque to tow with...and....in less than 4 months I blew the torque converter which toasted my tranny. Had the tranny rebuilt with heavier shift bands and put in a Banks TC.
Unfortunately, Banks is/was having problems with their converter locking up (they finally admitted they had a big problem after I pushed them enough - they ended up pulling from the market for a while.). Lucky for me, I didn't have any tranny problems. So....I ended up replacing it with a Suncoast triple disk TC and YEAH....no more problems.
The short of it.......just do it, it will save you many hassles later!
Yeah, I should clarify too. I have always used a single disk DTT converter, and towing has not been an issue. I don't tow heavy though. If you are honest with Bill on what you are going to use your truck for, then you can't go wrong following his recommendations.
Yeah those tranny war posts were downright brutal (some were even locked up) So now the question, are Bill and Stefan succeeding to marketing pressures or was there a flaw in their theories of disc lock-up that others picked up on.
That was my problem with this whole situation. When I started transmission hunting, narrowing down to dtt and gb, I talked to stefan several times and he told me the triples are overrated, used three thinner disks, so I should go with his single. James, his builder in TX, still doesn't think it is completely necessary but believes it may be a good idea. James also said Bill has been doing lots of r&d on triple disks and has exposed the weaknesses and fixed the problems. The more people I talk to and the more I read, the more I get confused.
I really couldn't tell you what my power level is, my transmission doesn't hold up to the power to know. I would hope I am at least 500 hp
I also think that is kind of funny. DTT said the triple was a weak design, but now they are building them? Ill just tell you, there is nothing weak about my GB triple disk, and I love it. Honestly i dont know if you would be better off with DTT's single or triple. I guess just go with what they reccomend even though it is the opposite of what they said a few years ago.
Eric
Eric
I run a DTT triple and the lockup seem to be more solid. As far as slowing you down in the 1/4, I don't know. It make sense that you would though. I was a little shocked when Bill/Stephan recommended triple over a single but it all depends on what you plan on doing with it and how much power you plan to eventually have.
I told them I was looking to be at 700+ hp later down the road and plan on taking her to the track once or twice
. At that power level they recommended I go with a triple because I'll run right through a single.
. At that power level they recommended I go with a triple because I'll run right through a single. I also think that is kind of funny. DTT said the triple was a weak design, but now they are building them? Ill just tell you, there is nothing weak about my GB triple disk, and I love it. Honestly i dont know if you would be better off with DTT's single or triple. I guess just go with what they reccomend even though it is the opposite of what they said a few years ago.
Eric
Eric
Last edited by J Double; Dec 17, 2006 at 05:07 PM. Reason: drinkng and typing don't mix
