Transmission temp sender
Installing trans temp gauge in my 01 Dodge 47RE. Guy at local Diesel performance shop said I could put sender in 1 of the 1/8th"tapped holes on passenger side of case. He said there are five plugs and to put it in third from front. I can only find 4 plugs. Will this work? and if so which hole do I use?
it will work, but it won't give you accurate readings, it'll just make your guage move. i read somewhere on here that the hole your speaking of is only part of the fluid or what not and is inaccurate so i wouldn't recommend it, but it's your choice/truck/tranny.
the proper place for location should be in the "hot line" going from the tranny to the heat exchanger, this will give you the hottest readings and let you know of too high of temps before something bad happens.
i've got a link to a good thread for you, but i gotta find it first, i'll be right back...
oh, by the way, welcome to the site, i saw this is your first post, hope we can be of some assistance to ya, don't forget to fill out your signature so we can see what you have at a glance!
found it, this will explain everything. also, about the line they talk about with the fitting already in it, www.dieselmanor.com also them now, and more than likely cheaper that getting one from the dealership.
https://www.dieseltruckresource.com/...d.php?t=116888
hope this helps, let me know if it does!
Or you could save $80 and get one of these, works very well and easy install:
http://www.genosgarage.com/prodinfo....ber=VULCAN_VTA
sleepr tsi
Nov 25, 2008 11:08 AM
ngkefalides
0
Aug 12, 2008 08:33 PM
jd2015
Jan 16, 2006 09:25 AM
thefb
Aug 4, 2004 01:54 PM
