Transmission interchange
Old Oct 6, 2006 | 10:05 PM
GlennRMK's Avatar
My buddy has a 96 Ram 1500 5.9 gasser. The 46RE took a dump. He found a blown V10 that has the 47RE. Will the V10 tranny bolt up to the 5.9 V8?
He also found a few wrecked 12 valve Cummins with the NV4500. If you buy the 5.9 gas bellhousing, can you bolt that transmission to the gasser?
Thanks guys
Old Oct 7, 2006 | 09:28 AM
gmctd's Avatar
Simple economics rule out anything but having the 46re rebuilt - input shafts are larger, output shafts are larger, torque converters are totally different, flywheels\clutches are different, rework for clutch pedal and hydraulic cylinders, driveshafts totally different size, incl yokes, u-joints, carrier.
Etc......
el jefe
Oct 19, 2005 06:26 PM
360ramcharger
Jul 7, 2005 08:16 AM
furious70
Sep 2, 2003 10:39 AM
