Trans Temp Gauge
Old Sep 15, 2005 | 09:42 AM
Tayloe08's Avatar
Trans Temp Gauge
Just got my Isspro gauges!!! Unfortunately I will not be able to install them for a week or so because of work! I know I will have questions during the install so please bear my ignorance.
To start the questioning, I am not sure about the install of the trans temp sensor. The directions say drain the trans pan, lower the pan and then tap for sensor, replace and refill. Is this the easiest way?? I was thinking it went in one of the trans lines. Any advice will be much appreciated. Thanks
Old Sep 15, 2005 | 09:46 AM
infidel's Avatar
Best way is to buy an output line for a '95 tranny that has a port in it and trade it for your stock one.
Dealer part number CH05011244AA
Old Sep 15, 2005 | 03:10 PM
nubbs00's Avatar
On the drivers side of the trans there is a 1/4'' plug in the case just behind the bell housing, above the pan. All you need is a couple of fittings to make it fit. It seams to give accurate readings. Mine Works Great!!
Old Sep 15, 2005 | 06:22 PM
Tayloe08's Avatar
I was looking through Geno's Garage catalog today and noticed a B&M Drain Plug. The drain plug has a removable plug in the end of it to drain fluid. The ad states you can easily add a temp. sensor in its place. The plug is only $10. How accurate would the readings be and what is everyone's advice on this? Thanks
Old Sep 15, 2005 | 07:03 PM
Tayloe08's Avatar
I think I might have just found my answer! The trans pan will have to be dropped in order to drill a tap for the B&M drain plug.... still not helping me any! Is this correct? I guess I will order the line or try and locate the plug and buy the fittings.
Old Sep 16, 2005 | 12:27 AM
J BODY's Avatar
I agree with Bill, go with the line.
Old Sep 16, 2005 | 10:57 AM
infidel's Avatar
The drain plug is a good idea, but the sender in the pan isn't. Sure it's better than no gauge at all but you are measuring the coolest fluid in the system. Ever think there might be a good reason the stock idiot light sender is in the output flow to the cooler, the hottest fluid in the system?
Easiest doesn't always equate to best.
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
