trans. temp gauge
Old Mar 8, 2005 | 06:09 AM
rattleram's Avatar
Question trans. temp gauge
Hey everyone, i was wondering if anyone has put in a after market temp gauge, and were did you hook into?Did you leave the factory senser alone so it still worked?
Old Mar 8, 2005 | 06:20 AM
mishkaya's Avatar
Hello
Most people either get a tranny pan with the port included to hook up their sender, or use the hot line with a port included (available from Mass Diesel) or Dodge (The part number at the Dodge dealer is CH05011244AA). The factory sensor does not need touched.
mishkaya
Old Mar 8, 2005 | 04:30 PM
phox_mulder's Avatar
I used the replacement hot line.
You want to leave the factory temp sensor alone, as I'm sure removing or disconnecting it would make the ECM or PCM do strange things.
phox
Old Mar 8, 2005 | 05:24 PM
cumminsdriver635's Avatar
You can pull the factory sensor out, and jump across it with a certain sized resistor, to make everything work right still. If you dont jump a resistor across it, you will lose overdrive, and TC lockup; as the fluid has to be showing warm enough for it to let o/d and tc lockup to happen. If someone would please chime in with the right sized resistor i would appreciate it, as i believe i might buy a tranny temp gauge soon too. Also, what is about the hottest you should let your tranny get while hauling a load? Ive heard around 200? Thanks
Eric
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
