trans temp
Old Sep 4, 2007 | 04:39 PM
dirtycj5's Avatar
trans temp
im hooking up a tranz tem gauge and i have a adapter that goes to the hot line before the cooler my question is which is the hot line? say your on the drivers side of the truck there are 2 lines one is on the left of the shift linkage that goes to the outher side of the block(pass side) to a heat exchanger and then to the cooler or is it the one on the right of the linkage that goes stright to the cooler?
also how many qts of atf is needed just for a filter change 4 or 5 qts i did it before just cant rember how much it was
thanks
Old Sep 4, 2007 | 05:16 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
The hot line will go the the heat exchanger first, then on to the cooler. Then the oil is returned to the tranny.
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
