towing power
Old May 7, 2006 | 12:51 PM
fourspeedracer's Avatar
towing power
Hi.. I am new to the deisel truck thing i have a 98 24v the problen i have is it looses power very badly on hills on the interstate while towing a 8000lb trailer. If you push on the pedal just a little it will try to go push more and it makes no differance. I went up a long grade 7 miles 7% grade and ran it in 3rd and ran it at 2300rpm's and it did fine. then i found out if you floor it in 3rd and run it up to say 2500 it will tow great on hills for a ways. you can tell buy the way the motor sounds snd feels it got alot more power and you can hear the turbo sound more this truck is all stock but the resanator has been removed but thas all. any ideas....thanks
Old May 7, 2006 | 01:19 PM
nitrousn's Avatar
Get fuel pressure,boost,trans temp. and a pyro[pre turbo]. Having the guages will tell you alot about whats going on under the hood. That would be the best money you will spend. Then you will know how much boost pressure along with the rest of the readings.
Old May 7, 2006 | 08:55 PM
Haulin_in_Dixie's Avatar
RV275 injectors, EZ chip, and Scotty II.
Old May 8, 2006 | 04:37 AM
have a fuel gauge. if i put gauges in it not sure what the reading should be . cant see where to hook up the boost gauge. also can a waste gate hang or something and cause this problem?
Old May 14, 2006 | 10:30 PM
Big Deezul's Avatar
You really need to get all 3 gauges (fuel, boost and egt) hooked up before we could make any educated suggestions on what you should do. I am shocked you would tow that heavy with out a egt gauge. As mentiond above, RV275's an EZ and a good air intake..i would throw a good exhaust on too, would be a great towing truck. In fact I ran that exact setup and could pull 8k lbs up any grade at just about any speed I chose with no problems....but I would have never done it with out gauges
Old May 14, 2006 | 10:33 PM
J BODY's Avatar
My trailer is about 8500 and the quoted combo above worked great for me!
Old May 14, 2006 | 10:37 PM
Buckshotmckee's Avatar
Welcome to the DTR! Fill in your sig so we know how your rig is set up.
Old May 15, 2006 | 10:27 AM
caffecapri's Avatar
I HAD the same problem pulling my trailer..stock. Now, check my signature for mods....everything helped. The Van Aaken is another option to the Edge EZ - both good from what I've heard. Now, I can keep 70mph (and perhaps even gain speed) going up hills with my trailer (8k enclosed) behind me. Much more enjoyable towing experience.
May try injectors next.
Old May 15, 2006 | 10:32 AM
RustyJC's Avatar
See signature. This combo will tow a tall 16K GVWR 5th wheel (also in signature) up a 6% grade at 70 MPH in 6th.
Rusty
edonald849
Feb 22, 2009 04:44 PM
Trusty Steed
Feb 24, 2004 07:11 AM
cscobb1
Aug 10, 2003 10:22 PM
awmasparky
Jul 15, 2003 02:19 PM
tlampman
Dec 23, 2002 11:29 AM
