Totally Confused!! TST or Edge
#31
It is hard to hold a steady 15 pounds on the launch. Once it hits 8 or so it wants to keep climbing fast. Not the best thing for bracket racing. I usually launch at 6 to 8 pounds when I'm bracket racing so it's more controllable. I can run consistent 13.30s with an 8 pound launch and it is still pulling 1.8 60 foots. I able to light the prestage, build the 8 pounds really fast and then bump the truck in until I've lit both. Keeps people from sneaking up on me by staging quick.( non-courtesy stagers ) As I am usually the first to light both lights using this method. No burnouts needed with a 4X4.
#32
I was having problems holding 15psi with the TST too. I normally like to leave at 15psi. The twins spool wicked fast from there. They will hit max boost on the 1-2 shift, with a 15psi launch. Very little smoke too. We will get a lot of 130* track temp days, but we don't get near the humidity that you guys do.
Paul
Paul
mjpalmer
05-19-2005 11:34 AM
stutz
38
02-23-2005 11:14 AM
