Torque managment wire?
Old Apr 15, 2009 | 08:31 AM
2141pete's Avatar
I've seen in a few posts on diferent boards that there is a wire you can cut to get rid of the Tq managment. I have an extra switch to runt through it and I'm headed to the track tonight. Can someone please help me so I can run decent tonight
Old Apr 15, 2009 | 11:45 AM
2141pete's Avatar
Anybody? I think it will be the same wires used in the BD RAD.
Old Apr 15, 2009 | 05:52 PM
Dinner's Avatar
Hmm, brings up a good point. Is there a way of adding a switch or a switch/regulator that we are able to shut off voltage or adjust voltage in order to remove or lower TM?
Old Apr 15, 2009 | 10:07 PM
psd tuner's Avatar
i dunno to only thing is to get a smarty...it stacks really well with ur quad
Old Apr 15, 2009 | 11:17 PM
2141pete's Avatar
I had a smarty and sold it. It dropped my trap speed by 4-5mph and didnt let me 60' hard enough.
Old Apr 16, 2009 | 12:19 PM
2141pete's Avatar
Here is the answer I got on another forum
I have cut the wires and it works. Against the firewall, above and to the right of the valve cover are two connectors. One has a white connection lever, the other a black connection lever. The black harness has the torque management wire (white with black tracer), the white harness has the speed eliminator (white with orange tracer). I cut the white with black trcer wire and then started truck. It started and ran fine only the tach and speedo did not work. I verified by doing a few launches in my driveway. I then tied into a toggle on my dash and have torque mangement off or on. After I purchased the smarty and loaded it, the torque management is the same as if the switch is off. So, yes smarty does remove torque mangement. I will probably remove the toggle and wire back in the way it was from the factory. I talked with Dave from here. He goes by fishin2deep4u. He was a huge help. I am sure he will chime in sooner or later. I believe the mod will work on 2000 through 2002 trucks with autos. It should work on some 2003 and 2004 trucks also. If it does't, just solder the wires back together, no loss, no foul.
Old Apr 16, 2009 | 04:44 PM
Dinner's Avatar
Hmm sounds interesting! I may have to have a peak at those two electrical plugs while I'm under the hood next time.
I wonder if there is a way to eliminate the TM (with an adjustable resistor) just enough, but still able to keep tach and speedo? Or does TM work with 12 volts, and then if lets say you adjust down to 10 volts, TM doesn't work and neither does tach or speedo..
Old Apr 16, 2009 | 05:46 PM
2141pete's Avatar
I was thinking there would have to be some sort of resistor. I cut the wire today and it didnt work, I could only build 10 psi.
atown
Jan 11, 2012 01:39 PM
1985cucv
May 11, 2009 09:07 PM
jtskir222
24
Oct 15, 2006 06:48 PM
Mav
Aug 16, 2006 11:20 AM
TPilaske
16
Nov 22, 2002 08:15 PM
