took first trip with ez installed... WOW!
Old Dec 24, 2002 | 04:00 PM
j's Avatar
j
just came back from the coast after the first long trip with the trailer after installing my ez and 4" exhaust. (had a comp, but had problems.. long story). all i can say is it is definately worth it!! coming back from the coast there is a 7-8% (varies) grade that is about 4 miles long. i used to be in 2nd gear wound out to keep 55 mph. now i was in 3rd and accelerating to the point i had to back off due to cars i was catching. my trailer weighs about 9000#'s give/take a few hundred. i now have a slight shutter when it shifts from 3rd to o.d. and is loaded. think that may be the tranny screaming "STOP IT". anyway just thought i'd throw my experience out there for anyone considering the purchase.
Old Dec 24, 2002 | 05:02 PM
rattle_rattle's Avatar
Re:took first trip with ez installed... WOW!
Thanks for the report. I haven't had a trailer hooked up since I installed the EZ. I'm lookin' forward to it though!
Old Dec 24, 2002 | 06:29 PM
Fishcop's Avatar
j....any mods to the trans or are you stock?
Old Dec 24, 2002 | 06:33 PM
erics76's Avatar
I was hoping to install my edge ez yesterday, but the map sensor plug on the edge was different than the one on my truck. Called Edge, and they said I needed an adaptor for $20. I wish I would have known that when I ordered it, would have saved me a week of having to look at my edge ez sitting on the table. Anyone else had this problem?
Old Dec 24, 2002 | 07:39 PM
phox_mulder's Avatar
[quote author=erics76 link=board=4;threadid=8766;start=0#84553 date=1040776402]<br>I was hoping to install my edge ez yesterday, but the map sensor plug on the edge was different than the one on my truck. [/quote]<br><br>Did you buy it from an individual or from an authorized dealer?<br><br><br>phox
Old Dec 24, 2002 | 09:10 PM
erics76's Avatar
I got it from premier performance. When I ordered it, I put down 2002, but the box says 2001 on it. I was never asked if I wanted an adaptor or not. This would explain the difference in plugs, but is the adaptor necessary for 2002's, or do they make a edge ez with the 2002 map sensor plug on it?
Old Dec 24, 2002 | 09:55 PM
Stamey's Avatar
OK, I want to know the long story about the Comp. I am thinking of getting one and I want to know if I may run into the same, whatever happened.<br>You can email it at me if you don't want to post.<br><br>Thanks,<br>Chris
Old Dec 24, 2002 | 11:09 PM
[quote author=erics76 link=board=4;threadid=8766;start=0#84580 date=1040785820]<br>I got it from premier performance. When I ordered it, I put down 2002, but the box says 2001 on it. I was never asked if I wanted an adaptor or not. This would explain the difference in plugs, but is the adaptor necessary for 2002's, or do they make a edge ez with the 2002 map sensor plug on it?<br>[/quote]<br><br>I can't remember for sure, but I don't think Edge made a new box for 2002.<br>Everything is the same except for that plug, and it wouldn't be economical for Edge to do that.<br>(especially with it being the last of the 2nd generation trucks)<br><br>A lot cheaper to just make an adaptor to go along with the thousands of boxes already out there.<br>You should have got the adaptor along with the box from the supplier.<br>Maybe that supplier wasn't aware of the change, or Edge forgot to tell them.<br>I think I've even heard of Edge giving out adaptors for nothing, or just shipping.<br>Maybe that's what the $20.00 is for?<br><br>phox<br>
Old Dec 24, 2002 | 11:29 PM
erics76's Avatar
You're probably right because when I talked to Edge, they knew that I needed a adaptor when I told him I had a 2002 truck, and hadn't told them anything else. $20 sounded pretty cheap to me considering that it'll take a male and female map connector for 2001 and a male and female for 2002 to make the adaptor and those connectors aren't cheap. Just wish I would have know that before so I could be enjoying the power now instread of maybe friday. Thanks for the Info.
Old Dec 25, 2002 | 02:30 AM
Dieseldude4x4's Avatar
Installed mine several months ago and absolutely love it. Looking at bigger injectors but that will require another clutch and on and on. The BOMB bug is alive.
Old Dec 25, 2002 | 06:58 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=phox_mulder link=board=4;threadid=8766;start=0#84609 date=1040792985]<br>I can't remember for sure, but I don't think Edge made a new box for 2002.<br>[/quote]<br><br>Actually, Edge did build a 2002 box with the proper plugs. If you got shipped an '01 box when you asked for an 02, it was shipped in error.<br><br>Rod<br>Just waitin' for everyone else to wake up. I wanna open Christmas presents ;D
Old Dec 25, 2002 | 12:43 PM
erics76's Avatar
Just looked at www.citydiesel.net. They've got 2001 and 2002 edge ez's, so they did make one for 2002. They've also got the 2001-2002 adapter for $7. Guess I should have looked there first
Old Dec 26, 2002 | 10:14 AM
j's Avatar
j
the 2001 you have is for a 2001, i sent you a private e-mail re:this. you should send it back for a 2002 and dont buy the extra plug.
Old Dec 26, 2002 | 10:19 AM
j's Avatar
j
the short version of the long story is that i went through 2 comp's after getting the right one. they all flagged the ck engine light and i heard this is very common for 2002 models for some reason. i finally decided on an ez and am very happy with my decision. i will probably upgrade the tranny before adding anymore power though as it is already shuddering (not bad at all though). i bought mine through www.sourceautomotive.biz rip is a very very customer freindly guy and went out of his way to make sure edge didnt screw up again like they did the first time. when i still had problems with the comp after that, he made sure i was ok with my decision to go with an ez and made me feel like i was the only customer. he did this even before i had purchased anything through him when i wasn't even a customer.
Old Dec 26, 2002 | 03:38 PM
admin's Avatar
Eric,<br><br>I hope you didn't buy the adaptor plug yet. You ordered the EZ through my site and Premier Performance shipped it. I don't know if the mistake was made on my side or theirs to be honest, but I do have a order for a 2002 EZ, not a 2001. I left you a message so I hope you call me back, and we can straighten this out. <br><br>If you're willing, what I'd like to do is a call tag and ship you a new one in return for the one you have now. By doing this, you pay nothing for a new adaptor plug. Either way, message me, or call me back and we can go from there. Sorry about the confusion, but I'll make sure you get the right product in hand, even though it may be a little late.<br><br>Jack
Mike L
Jan 6, 2015 03:44 PM
DNRCustoms
Feb 12, 2009 12:15 PM
SlowSixSpeed
24
Jun 23, 2008 10:12 AM
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
