timing advance, how long?
Old Jan 7, 2005 | 11:20 AM
hank's Avatar
How long should it take to advance the timing on my 94 12v. Which sound more reasonable 30-45 min or 2-3 hrs? Thanks no sig yet, newbie. Mine '94 reg cab 12v auto, Her's 01 swb ext cab auto. May the fun begin!!
Old Jan 7, 2005 | 11:24 AM
CTD NUT's Avatar
Welcome to DTR!.......A pro should be able to check and advance the timing in a little over an hour.......
Old Jan 7, 2005 | 11:28 AM
hank's Avatar
Thanks, can I get a fuel plate for under $250 #10 tst or an equal.
Old Jan 7, 2005 | 12:04 PM
CTD NUT's Avatar
Yup, you should be able to.........or if you are handy you can grind your stocker and block your wastegate - but only after you get a boost and egt gauge!.........I suggest grinding your plate to a #100 profile.........you should be able to do a search and find some pics of that plate...........I think gunracer has a pic of one in his gallery......
Old Jan 7, 2005 | 12:07 PM
hank's Avatar
Thanks I have met gunracer and we live close ........I may let him do it for me. Thanks
Old Jan 7, 2005 | 12:11 PM
gunracer1's Avatar
it takes more time to find tdc than it does to time it. once the balancer is marked with true tdc it takes 20 minutes or so to time it. then spin it back and double check the timing. but if it slips after you run it you need to pull it back down and reset it again. i have only had it slip once out of 20 or so trucks i have timed.
Old Jan 7, 2005 | 12:25 PM
hank's Avatar
Thanks gunracer I will get with you in couple weeks. Maybe we will do the plate too.
LanceD
15
Jan 12, 2004 05:23 PM
Davidp
Mar 16, 2003 11:40 AM
95ramtough
22
Jan 29, 2003 08:45 AM
Smokin
Nov 22, 2002 09:31 AM
