Thuren Track bar
1 Post
Installing a track bar isn't rocket science, but it is kind of a PITA, especially if you have any sort of lift at all and want to center the axle. I wouldn't buy a stock replacement knowing I'd have to pull the thing off in a couple of years and replace it, even if it was a lifetime warranty, free replacement. Prior to the Thuren track bar, I had a Luke's Link on the stock bar, and it worked alright but I had to tighten it up at every oil change. Not a huge problem to do, but I could see a rebuild coming soon on it. Bottom line, the Thuren bar works very well, it's awfully well-made, and I'd rather spend the money up front for a quality product that'll last a while and not make me jump through hoops a few miles down the road.
I have a question on how the joint end gets bolted into the frame. Reading the instruction. It looks like you just run a 3/4 bolt thrue the tapper hole and exspect the torque of the bolt to keep it in place and not use the tapper like intended. Is this right?
Dan
Dan
1 Post
Dan
Dan
so if you have a lift or want to put a lift later do you have to get the weld-in bar? i was wanting to do a 4 or 5 inch lift but i think i'm just going to do a leveling kit if anything. will the bolt on work with the leveling kit? and what if i do decide to do the bigger lift so i can run 35's?
1 Post
Mine is going to show up Monday (according to UPS) and I ordered it about 2 weeks ago.
Don's a little preoccupied with his wife ready to have their baby any minute.
Keep them in your prayers.
1 Post
I think he builds them to order, and has a lot of stuff going on all the time. Probably not stuff like a baby on the way, but I ordered mine a bit over a year ago and it took, well, about two weeks.
CTD2001
08-22-2009 10:03 PM
silkywoods
17
12-03-2007 05:09 PM
getblown5.9
25
12-08-2005 11:52 AM
