Turbo
IMO I'd go with the 12 to start with and some bigger sticks, cuz unless you plan on running around with your box turned up all the way all the time you aren't going to have enough fuel to push it.
I can't tell by you sig. but if you have an auto the 12 will be the way to go. If you have a stick you would probably be OK with the 14..
Since the 14 housing is already on there, try it. If it's too laggy you can away put the 12 housing on.
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
