valve spring questions
Old Feb 28, 2007 | 07:07 PM
Smokin Flatbed's Avatar
I am about to order a 4kgsk with hd springs, do I need to pull the head to put in the valve springs?
Old Feb 28, 2007 | 07:16 PM
clarson80's Avatar
I think all that comes off is the valve cover
Old Feb 28, 2007 | 08:18 PM
olbetsy98_12V's Avatar
No you dont have to but it would make it easier and safer. I know theres a tool that you can screw into your injector port and hook it to an air compressor and that will keep the cyilinder pressurized so the valve doesn't fall it to the cyilinder then you would really have to take the head off. I dont know were to find the tool at but maybe you could search the web and find it. If you go that way you better have a really good air compressor. Hopefully this helps.
Old Feb 28, 2007 | 08:21 PM
DIESELDENT's Avatar
I got a tool like that at autozone i use on on sbc for the same job mostly. it could probably be adapted.
Old Feb 28, 2007 | 08:38 PM
kbbt's Avatar
valves will not fall out if the piston is at tdc on each cylinder you are working on. using a stubby spring compression tool the head does not have to come off. K-D Tools Valve Spring Compressor 2078 works pretty good.
Old Mar 3, 2007 | 11:02 AM
I was hoping that you could put each cyl at tdc to hold the valves. Thanks for the advice.
BurrisWill
Jan 25, 2009 08:23 PM
DNRCustoms
Nov 24, 2008 09:30 PM
WhoCares79
Jun 3, 2008 11:45 AM
flynhigh205
Feb 26, 2008 10:33 AM
fishin fever
Mar 13, 2006 06:46 PM
