Third Gen Brakes for 2001.5 and 2002 Trucks
Old Nov 22, 2019 | 03:27 PM
  #31
This Diinosaur's Avatar
98.5 dodge front brakes
i have a 98.5 dodge that im trying to do this upgrade on and it seems like it was going to fit up until i went to put the 3rd gen rotor onto the 3rd gen hubs. Right now my old 2nd gen calipers has a little bracket or alignment type thing on the axle knuckle and now blocks the rotor from going on, it seems like everybody that has posted onto this thread has a early 2000's truck but was seeing if any of the late 90's trucks have done it, im temped to just cut the bracket type thing off because the caliper sat in between the thing and that should allow me to put the rotors on. Any advice?
Old Nov 30, 2019 | 12:00 PM
  #32
SIXSLUG's Avatar
IIRC you need third gen brackets, calipers, pads and rotors, not to mention 17" or larger wheels...
Old Dec 3, 2019 | 07:19 PM
  #33
ive been having problems trying to get this 3rd gen conversion to work properly, every step i take it seems like im taking backwards, i have purchased all the parts that you have listed above and they wont fit up to my axle, can somebody that has done this conversion take a picture of their brake setup and show me what they did to make it work
Old Dec 6, 2019 | 03:20 PM
  #34
u2slow's Avatar
You have the 94-99 style axle... AFAIK, the conversion doesn't work on these. The knuckles are quite different.
Old Dec 6, 2019 | 05:40 PM
  #35
AlpineRAM's Avatar
Yep. if the stock brake disk will not come off without removing the wheel bearing you have an incompatible version of the front axle.
Old Dec 10, 2024 | 10:12 AM
  #36
Jamesharrison@1's Avatar
Mine has disks and I've got factory 16'inch wheels.
Originally Posted by torquefan
I suppose you would also have to figure the cost of larger wheels into the project, as the factory 16s won't fit. That'll add thousands to the total.
Mine is a late 02 2nd gen and IT came with ALL THAT "". So It's Workin On Mine. ". FACTORY 4-WAY DISK AND FACTORY 16'INCH WHEELS...?
Old Dec 10, 2024 | 10:14 AM
  #37
u2slow's Avatar
3rdgen discs are bigger than 01-02, so bigger wheels are required.
Old Dec 10, 2024 | 12:09 PM
  #38
Ow ' OK "". I DIDN'T REALIZE THAT IT'S A SPECIAL CONVERSATION "". ON THE SAME PAGE NOW "" I KNOW THESE THREADS ARE OLD BUT THERE STILL INTERESTING " I WAS WANTIN TO TELL ONE GUY THAT I'M A RETIRED TRUCKER AND REAR DRUM BRAKES ARE THE ONLY BRAKES TO HAVE WHEN YOUR DOING SOME ". REAL SERIOUS. "" TOWING/HAULING ' YOU KNOW GROSS 40.000 "" THOSE REAR DISK WILL GET YOU IN SERIOUS TROUBLE " THE'LL ". FADE. " RIGHT OUT" BUT I KNOW " HAVE TO KEEP THE DRUMS ADJ UP " IT'S PAIN SOMETIMES ". BUT THERE HAS TO BE A TRADE OUT SOMEWHERE"". HAY " THANKS FOR REPLY "". AFTER ALL THESE YEARS "". AMAZING "". James.oklahoma...KD5UTU
Old Dec 11, 2024 | 07:54 AM
  #39
Retired trucker...huh?
What did you drive for a truck?
What sort of part of the country did you drive?
Old Dec 11, 2024 | 08:23 AM
  #40
LonestarCowboy's Avatar
I have a 2001 3500 Dually with drum brakes. Is there a way to convert the back to disk?
Old Dec 11, 2024 | 09:21 AM
  #41
Yes. Roll the drum braked axle out from under the truck. Roll under the hard to find disc braked Dana 80 2nd gen axle. Bolt it up and re install driveshaft, brake lines and shocks.
You will then need to deal with the brake proportioning valve to get the brake to work right.
Old Dec 11, 2024 | 12:50 PM
  #42
u2slow's Avatar
If you have time and are crafty.... Some people have changed the axle flange so that all the factory disc stuff bolts on.
This is a Ford axle, but the flanges and disc componentry are identical. Rotor choice would be a variable. https://www.fordmann.com/F350.rear_disc_brakes.htm
FWIW, i have extra disc hardware to do a conversion , but still decided to rebuild the drum brakes. Reason being, if I was going disc, I want big ones - stuff that needs 17" or 19.5" wheels.
Old Jan 6, 2025 | 08:33 PM
  #43
SIXSLUG's Avatar
Wow another resurrected post from the archives
Guess I should get this conversion done as I have been acquiring everything over the years and need to pull the trigger on it. And regain some shelf space in the shop!!
Never a dull moment....
Kurt
Patrick Campbell
39
Apr 24, 2025 08:06 PM
conchfarmer
17
Feb 13, 2008 04:51 PM
humboldt
Aug 1, 2007 02:26 PM
jeepinaround
Feb 21, 2007 09:18 AM
Mike S.
Aug 2, 2006 08:10 AM
