Third Gen rear-end under a First Gen
Old Aug 1, 2006 | 02:28 PM
Mike S.'s Avatar
Question Third Gen rear-end under a First Gen
What would be involved? I haven't a clue, but I'm in a position where I probably have to replace the rear axle housing in my first gen and I'm wondering if a third gen would fit ok. Having four-wheel disc brakes would be great.
Old Aug 1, 2006 | 03:18 PM
apwatson50's Avatar
If its a dana 80 thats a definate yes, if its the new AAM not sure. What gear ratio do you have? As i'm fairly sure that the new trucks only come with 3.73 gear ratio's and maybe 4.10's. Also do they have hub centric wheels now?
Old Aug 1, 2006 | 03:36 PM
jrussell's Avatar
I would imagine the spring perch widths are different, but those are pretty easy to cut-off and weld on in the right spot.
Begle1's Avatar
If you just want disk brakes, you can supposedly bolt on front disks from a Chevy K-20 onto your rear axle...
http://ramchargercentral.com/index.p...owtoshow;id=66
There was another link like that floating around, don't know what happened to it though...
Old Aug 1, 2006 | 03:37 PM
jrussell's Avatar
You can?
Do the caliper brackets bolt-on and everything, or just the rotors?
Old Aug 1, 2006 | 03:40 PM
Begle1's Avatar
I edited my first post.
I got beat off the draw.
Supposedly you can do it; I think there was a more relavent link talking about a similar conversion on a Dana 71 rather that a 60, but I don't know where that one went...
EDIT: Voila!
http://www.off-road.com/toyota/tech/dana70discbrakes/
Old Aug 1, 2006 | 04:26 PM
Very nice, but that leaves you with no parking prake.
Old Aug 1, 2006 | 04:36 PM
apwatson50's Avatar
How about a line lock/micro brake?
or some good ole chocks. lol
Old Aug 1, 2006 | 04:39 PM
jrussell's Avatar
Yeah, a line lock should work fine for most of us.
4x4 owners can probably get a T-case parking brake too, but those are not always easy to install.
Old Aug 1, 2006 | 04:51 PM
apwatson50's Avatar
How about a tailshaft mounted drum brake. The ole 65 2wd ford has one, and there's a tranny sitting in the barn with one mounted on it.
Old Aug 1, 2006 | 04:54 PM
jrussell's Avatar
Sounds like an older 2wd version of a T-case brake. I've heard you can get the parts and custom make one for just about any vehicle where there is enough room to clear the disc. I think the discs and calipers come from some kind of airport work vehicle.
Old Aug 1, 2006 | 05:26 PM
Flake's Avatar
You don't want to use a line lock for a parking brake, it draws too much power and will kill you batt(happend to me on my old rock crawler). The Mico lock is made to be used as a park brake no problem, it's just kinda expensive.
These guys make nice rear disc kits, I've used a Chrysler 9.25 and a Dana 70 kit from them with no problems. You can also get their kits with Caddy calipers with a mechanical park brake built into the caliper.
http://www.tsmmfg.com/Dodge_Truck.htm
Old Aug 1, 2006 | 08:41 PM
Begle1's Avatar
So can I ask a couple of questions now?
1. What is the difference between a Dana 70 and Dana 71? How do you know which you have?
2. Has anybody ever installed a drive-shaft brake on these trucks before? I take it that's what ya'll are talking about when you say "tail-shaft" brake, correct?
Old Aug 2, 2006 | 08:10 AM
apwatson50's Avatar
They're actually drum brakes, not disk. They're from the sixties at least. Did they have disc brakes back then? lol
Also on our plow truck we have a manual line lock or micro brake. I don't really know what the difference is. Seems like they both do the same thing. You do have to route brake lines into the cab for it, but i'm pretty sure there are manual actuated ones that just have a lever into the cab.
gilbertsdodge
Oct 22, 2009 04:06 AM
conchfarmer
17
Feb 13, 2008 04:51 PM
doorguy
Jun 8, 2007 06:19 AM
jeepinaround
Feb 21, 2007 09:18 AM
Paul Winey
Competition / Pulls / OffRoad
20
Oct 12, 2005 05:10 PM
