thinking about twins
Old Jul 3, 2006 | 11:24 PM
rebal's Avatar
OK all you twins out there Im thinking about doing it to my HO
how about some pros and cons
like head gasket issues its a tower so reliablity is #1 what needs to be done to keep it that way?
thanks
Old Jul 4, 2006 | 01:16 AM
LanceD's Avatar
whats there to think about? if you can afford it, do it! thats the only downfall I think is the price.
Old Jul 4, 2006 | 09:11 AM
getblown5.9's Avatar
def gonna need 0-ring or frie rings with new headgasket and prolly gonna want studs in there as well, they are gonna push a larger volume of air and will make big boost numbers which will kill the stock headgasket...
i know thats my next step after the tranny is back in the truck
Old Jul 4, 2006 | 09:17 AM
12valve's Avatar
OR O-RING AND FIRE RINGS
Old Jul 4, 2006 | 09:23 AM
ratsun's Avatar
If all you got for fuel 1.6s and the smarty for timing then I think you will get away with just a set of studs. I ran stock (no studs or orings) for close to a year with a drag comp and Jammer IIs untill I popped the HG. IMO if you dont add any more fuel you will be good to go but................who do you know thats owned a twinned turbo truck and hasnt added more fuel
Old Jul 4, 2006 | 09:57 AM
rebal's Avatar
got to love it! I do plan on more fuel maybe mach4s as it sits now with the 1.6s egts are not an issue. but, im greedy and need more power I might call piers and see how bad they will ding me. 425-450 usable HP ,is that to much to shoot for?
Old Jul 4, 2006 | 11:53 AM
GlennRMK's Avatar
How does spool compare with an HX35 or HX35-14 and HT3B or similar combo? Same as stock? Quicker then stock? Slower then stock, but quicker then a 62/12 single?
Old Jul 4, 2006 | 07:26 PM
ratsun's Avatar
_______________
I didnt notice any difference with the PDR set that I use ( but memory isnt one of my strong points )
To save money I used my stock 35-12 with their towing twins set and even with the tight converter its awsome.
rebal
If you plan on upping the fuel to a Mach 4 I would say atleast run a set of studs in to be safe.
Old Jul 6, 2006 | 01:18 AM
95ram's Avatar
My old set was a 35/14-3b and I had boost at about 1200 RPM. They spooled right now. The 35 was killing me on top end though so it had to go. A 40/14-3b works for towing also. You get a little more are and spool up is still good.
Old Jul 6, 2006 | 09:49 AM
Tiger Rag's Avatar
I've been running the BD twins and I only put head studs in on my HO. I know some running twins that only retorqued head bolts. I don't recommend that personally but you can sometimes get away with that.
I'm going to oring at somepoint but I'm holding so far. When I do, I'll do a marine head gasket to ease the compression some of the HO engine.
Old Jul 6, 2006 | 09:59 AM
Dshiftff's Avatar
BD twins by far the cheapest homeontheroad.org $2895
hope to order a set this week myself
PM me if the link gets deleted
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
Nashirak
17
Nov 22, 2002 03:35 PM
