These things are HUGE (compared to the stock springs)
The pictures should tell most of it:
new spring - left || stock 12v spring - right
I didn't realize the new valve springs would be ~.375" taller. The slight beehive makes them seem wider. I'm thinking they'll definately get a good workout with the new cam.
brandon.
brandon.
Hey Brandon those look like there good for a lot more lift before coil-bind
Is the cam your going to run have much more lift? What about open pressure?
Details man I need details
Are those F1 springs?
Are those for a Helix cam?
Originally Posted by Forrest Nearing
are you running different valves or trick retainers?
brandon.
Originally Posted by Begle1
So you don't need beefier pushrods or anything with valve springs that size?
brandon.
someone said something about trick valves and valve retainers? Later on I plan on finding a used head maybe out of a crashed cummins 12v and take my time in rebuilding it. I was plannign on making the intake valves bigger and porting the intake side, I never really gave any thought to different valves what kind to ppl use? its not like we tach to 10 grand and need stainless or higher? i could be wrong tho.
my point is if you install those things at stock height, aren't they gonna be pretty close to bind? obviously you're going to have more pressure, but are you going to have more distance to bind?
When I have seen valve spring upgrades, albeit on gassers, and they have thicker wire, to a point, then they start doubling and tripling the springs when more pressure is necessary.
Is there just that much extra room in these valve setups?
Thanks,
Chris
Originally Posted by Stamey
That's what it was kind of seeming to me. If the wire is thicker, and the springs are taller, once compressed into the same space as the stock springs occupied, won't these be more likely to bind?
Thanks,
Chris
Thanks,
Chris
brandno.
Brandon, I don't think that your gonna have any coil bind with those springs. If you count the number of loops, they match the stocker. They are just stretched out more. That must be one heck of a cam, you notching the pistons? Its looks like you got one cool project going there. I'm throwing around about building a motor for my truck. I'm bored...
