Is There a Way To Tell If A VP Has Been Changed??
Old Jun 11, 2007 | 09:32 AM
chuxtruk's Avatar
Or is still the stock original VP-44? This truck had the dealer fix for the lift pump problem and had the pump in the tank solution. I was wondering if this was done before there were any VP problems or after replacing the VP. Any way to tell?? Thanks you guys!!
Old Jun 11, 2007 | 12:27 PM
fiveology's Avatar
If the dealer did the intank, they may have also done a VP, any dealer should be able to run your vin and see if it was replaced by a dealer. If it was replaced somewhere other then a dealership, you probably will not be able to find out.
Old Jun 11, 2007 | 02:00 PM
iforge03's Avatar
a lot of times there will be a sticker on the top of the pump that says "reman".
Old Jun 11, 2007 | 05:38 PM
Red3quarter's Avatar
Also, reman pumps are painted black. The one my dealer put in under warranty was painted black.
rossco
Aug 30, 2007 09:51 PM
tony597fitter
Dec 17, 2006 06:30 PM
lovinCTD59
Dec 3, 2006 07:31 PM
digbog
Sep 2, 2006 07:57 PM
mr T
Nov 22, 2004 07:58 AM
