temporary Fuel Pressure Gauge
Will an A.C Charge hose fit the test pot on the filter cannister??
Unfortunately I don't think you can buy a charge hose up here. i had one that i brought back from the states but it has gone AWOL.
What gauge do u use?? Just a water gauge from the hardware store?
Yes sir the shrader on the a/c hose will fit the shrader valve on the filter canister and also the port on the vp-44.
Not sure about the water pressure gauge, I think I used an oil pressure gauge.
wayne
wayne
Or.....Just install a guage that you can monitor full time.
Folks have installed them in the A-pillar, on the dash, on the steering wheel housing, the dash cubby hole, the floor console.........the possibilities are endless.
Yes I will be definitely...... I'm far from home right now and won't be returning until like May. I am going to do Pyro, Boost and Fuel pressure on the A-pillar but for now I'd like to be able to test the fuel pressure, so I'll rig up one of these setups as mentioned.
Not sure where I'm going to find a hose that will fit that test port though....
Try a local Chain type auto parts store and pick up an inexpensive gauge with install kit.
Shouldn't have to spend much $$, and you can route the small plastic tubing up and zip-tie the gauge temporarily to a wiper arm to view.
http://www.partsamerica.com/ProductD...artnumber=1561
TxDiesel007
Aug 20, 2006 12:05 AM
ataboy9026
Dec 2, 2005 06:15 PM
