Synthetic Oil ... When?
Old Jan 11, 2003 | 03:00 PM
DPG's Avatar
DPG
Re:Synthetic Oil ... When?
If you are going to be changing your oil every 3750 miles, synthetic is deffinately not worth the expense. One of the advantages of synthetic is the longer change interval.
Old Jan 11, 2003 | 03:23 PM
Marine's Avatar
Veteran: Marine Corp
I went to Rotella syn at 50,000. I'll do a change at 7500 mi.<br><br>Mike
Old Jan 11, 2003 | 03:42 PM
Ruralmedic's Avatar
It took awhile to convince myself to switch to synthetics, but after I have, it's one of those things that I wish I had done sooner. You'll find the biggest opponents to synthetics are the one's that have never used it. <br><br>The reason for the 3750 mile drain interval for conventional petroleum based oil is because it is more prone to breakdown, especially if worked hard. Too many impurities are left in after refining. Synthetics are designed for lubricity, resist degradation, and perform much better at temperature extremes. Drain intervals can be extended, so expense wise, you'll save in the long run. Not to mention, using less foreign, middle eastern crude. <br><br>I plan to performance modify my truck soon by adding larger injectors and a fueling box, and that's another reason why I wanted an advanced lube.
Old Jan 12, 2003 | 09:17 AM
rshelton88's Avatar
So, is oil sampling/testing usually only done with the synthetics because of its longer life?
Old Jan 12, 2003 | 10:26 AM
Marine's Avatar
[quote author=Bull Dog link=board=7;threadid=9164;start=15#91177 date=1042384621]<br>So, is oil sampling/testing usually only done with the synthetics because of its longer life?<br>[/quote]<br><br>Yes. It is also done to tell you what kind of wear is happening in the engine.<br><br>Mike
Roadstar
Jan 14, 2010 03:50 PM
Roadstar
Jan 11, 2010 06:44 PM
bobbywebb
Oct 29, 2006 09:50 PM
rico334
Jan 3, 2005 08:10 AM
snice
14
Apr 29, 2003 08:41 PM
