Superchip
Old Mar 18, 2005 | 10:27 AM
TDIDog's Avatar
Superchip
Hey has any body tried or know someone with the Superchip 3705 Max Micro Tuner? Apparently you can reset codes &
adjust fueling values etc. Just sounds interesting. Also supposed to add 70 hp.
jack
Old Mar 18, 2005 | 10:37 AM
high country's Avatar
I have one, it will not reset companion codes like 1693, but otherwise I have reset codes on a few different rigs with it. If you have a rig older then 00' you need a scanner to pull the codes and for a few more $$$ you can have some more power too. I run it on the 50 hp towing mode as it does the best job of getting out of the hole and I don't drive with my foot on the floor too often you should also get a boost fooler and block the wastegate to get the total performance available that is another $60. Before you do anything to your truck get gauges! I have a buddy buying a ip and lp, he bought the guages comp bhaf and installed them in reverse order over a couple months.....but sucked the ip before the gauges hit the pod bummer!
MOUSE
Nov 23, 2004 05:05 PM
dsl-nut
Apr 8, 2004 08:58 PM
fitzer
Feb 28, 2004 05:49 PM
DODGE4X4
16
Oct 5, 2003 01:35 PM
CWICKHAM
Dec 16, 2002 06:35 AM
