star wheel ?
Old Sep 12, 2006 | 04:12 PM
somis13's Avatar
star wheel ?
I turned mine and the spring in there went slack after a couple of turns, should I keep tension on it or turn it up so there is no tension? Im not getting any smoke
Old Sep 12, 2006 | 04:45 PM
oldsmokey97's Avatar
you can turn it as much as you want to. or untill the startwheel hits the front of the afc housing. It doesnt matter how far ya go.
If you still have the stock plate in the stock position, there wont be much smoke no matter what you do. you will have to either move the plate foreward (all the way) or buy a plate, or grind your own stocker to a #0 or a #100 to get any good out of it.
Old Sep 12, 2006 | 05:02 PM
somis13's Avatar
thanks, I have a #10 plate, but never installed it cuz it looks like I have to take two of the fuel lines off the pump to get access to the break off screw. so I just tried turning up the star wheel.
Old Sep 12, 2006 | 05:55 PM
displacedtexan's Avatar
You don't have to remove the lines. I have had my AFC cover off many times, and never messed with the lines. Remove the bracket that holds them together, and you can spread the lines enough. If you put the plate in you won't regret it. Well worth the effort, and it is a pretty easy job.
Old Sep 12, 2006 | 07:43 PM
infidel's Avatar
A '98 like somis has is harder to take the AFC cover off than previous years as the injector lines are different but can be done without removing the lines. The way I deal with the breakoff bolt on a '98 is with a 12" drill bit, just drill the head off with the bit in-between the lines. Once you remove the other screws and cover the headless screw turns out with just your fingers.
Old Sep 12, 2006 | 10:53 PM
somis13's Avatar
what size drill bit do you use for this? I really want to get the cam plate in. my truck has plenty of power with out weight behind it,but thats maybe 25 days out of the year. the rest of its life I tow 6500 pounds daily so more power is a must
Old Sep 13, 2006 | 09:38 AM
GR40RCapri's Avatar
Somis,
i would think a 3/8" drill would work for you...try to use a bit that is about the same size as the screw head, that way it takes the whole thing off, and just counters the screw shaft a bit...
just make sure you don't damage the LINES! or drill through the AFC mounting hole...it's soft aluminum..
good luck...
J
FYI- i took a hacksaw and slotted the screw, then a hammer and screwdriver spun it enough (the screwdriver alone was rounding the hole i slotted) to get the screwdriver in there to turn it...and i live in NEW ENGLAND...
Old Sep 13, 2006 | 10:34 AM
infidel's Avatar
I use a 1/4", it only needs to be the size of the screw shaft plus the 1/4" fits easily in-between the fuel lines.
You will be amazed how fast a sharp bit takes off the screw head, less than 30 seconds. Most break off screws also have a hole in the center that makes for easy centering. Don't lose the two washers under the drilled screw, you can reuse them.
On the star wheel-- Make sure to slide the AFC cover full forward before tightening it down. Sliding the cover is the major adjustment, turning the star wheel is fine tuning.
Old Sep 13, 2006 | 02:05 PM
i just used a good chisel/screw driver and beat the side of the screw and finally they do come out.
Old Sep 13, 2006 | 06:53 PM
infidel's Avatar
You have a '97, on a '98 the injector lines are different and pass right over the breakoff screw making it difficult to get at with a chisel without removing the lines.
jdr160
Jan 12, 2008 07:05 AM
Lance
22
May 30, 2003 09:51 PM
DuallyJeff
Mar 21, 2003 10:31 AM
mymaur
Feb 24, 2003 07:08 PM
DuallyJeff
20
Feb 21, 2003 05:58 PM
