Stacks
Stacks
Mornin' everyone!<br><br>I was wondering where you guys buy the kits for your stacks and how much they usually run. I haven't seen too many in the great state of Utah. :
. <br><br>I hoe this is posted in the right place. ???<br><br>Dave
Re:Stacks
Any big truck place has them. You can ask around on here. I am sure you will have some guys help more.<br><br>Here in Kentucky, a place called republic diesel has them, but that does you no good unless you want them shipped.
Re:Stacks
I ordered mine from www.berubes.com.<br>No one really has a kit, you usually have to buy want you want after you lay it out.<br>Look in the member photos section to see different applications.
Re:Stacks
I use my bed like normal. some things melt but I have never had anything catch fire. I will be building a box to go around the bottom of them more for looks but it will keep stuff from touching the tubeing. We have 3 different g/n drags now so we use them most of the time.<br>DM01
Re:Stacks
Hi there, Check out www.hotroddiesel.ca and go under the Research Truck link on the left hand side, They have a complete diagram with all measures and parts lists. INcluding where to cut holes in bed.<br><br>Hope it helps,<br>Maybe give them a call at <br>1877 655 1234 or (705) 439-3298<br><br>Hummin Cummins
Re:Stacks
[quote author=dieseldude4x4 link=board=7;threadid=15793;start=0#148623 date=1055434628]<br><br>No one really has a kit, you usually have to buy want you want after you lay it out.<br><br>[/quote]<br><br><br>There is a stack kit available, in any configuration you desire, PM/e-mail me for more information.<br><br>manualsrule@msn.com<br><br> Rob
Re:Stacks
Cruising 55 on level ground with no load, you can just hear a light rumble with mine even with the windows down. Now loaded up or acceleratings is a different story all together, but, mine is straight piped off the turbo. You can install the resonator or a muffler to get the desired sound you want clear down to no sound at all if you want to go that far.<br>I must admit on a long trip of 10 to 12 hours, mine will get annoying. I just pop in a set of ear plugs for the long haul. The short haul sounds really cool though.<br><br>Look in the member photos section on page 2 under dieseldude4x4's pics and hobbies to see some pics of my set up. I like them taller above the cab, gives them that sort of blappy sound if you know what I mean.
nfsommer
21
Apr 4, 2007 03:45 PM
rockittboy
Feb 3, 2006 12:38 AM
