sound insulation in cab
Old Apr 10, 2005 | 08:08 PM
displacedtexan's Avatar
I bought my truck 2 weeks ago, after wanting one for as long as I can remember... I love it so far...
Yesterday I had the exhaust done, I love it, always have loved that sound...
But my wife is not as fond of it as I am, so I want to try and muffle the noise in the cab to some extent if possible. My thinking was to use "Dynamat" or something like that... the stuff that they use for audio systems to keep sound out, starting in the corner of the cab right over my exhaust exit.
I was wondering if anyone here had attempted such a project already, and had any tips of advice on what works or maybe doesn't.
Thanks.
Old Apr 10, 2005 | 09:17 PM
MedicShawn's Avatar
There have been a couple of guys in the 3trd gen section that installed dynamat in the whole cab. One of the even used a decible meter to measure the sound difference. I think the difference was 1 decible. Which they said was noticeable.
Old Apr 10, 2005 | 11:37 PM
Thanks, the whole decibel scale makes no sense to me, I have read about it, but the way it changes is a little to abstract for me...
So I guess this project will be a go, I could always use another truck project...
Old Apr 11, 2005 | 12:21 AM
shawn085's Avatar
Hey do a search, somebody was saying they did it and it made a diffrence that was werth while. They used some stuff they picked up at the hardware store and tinfoil and made there own dynamat. It was a lot cheaper and worked great.
Old Apr 13, 2005 | 03:00 PM
Rockyhud's Avatar
I read an article on TDR very recently that dealt with this very topic. The guy, Andy, wrote a pretty good description of what he used and how it turned out along with a link to some pics he took of the project. The text of his write-up is what I've copied here. Hope this helps.
Steve
[quote from Turbo Diesel Register]
Sound Insulation the Cheap Way
Wanted to post this for everyone that would love to have there truck as quiet as a Lexus with out having to spend $3000 big ones to have someone at a stereo shop do it half ***. I found this stuff called Jiffy Seal at Lowe’s Hardware for $16.00 per 50' x 6" role that is used for sealing the edge of windows in construction. It is made of a tar compound that has adhesive on both sides. I compared it to a popular sound deadening material called HushMatt. It was very close in thickness and was just as sticky. The difference was that the HushMatt has one side that was foil painted black and cost about 300 times as much. I had my wife while on a weekly market trip pick me up the heaviest duty role of tin foil she could find. After pealing the first piece and adhering it to the tin foil and trimming a bit I found that I had made the same exact stuff as the HushMatt for the most part. A Hell of a lot cheaper.
I started with the inside of the doors and worked my way to sealing all the interior surfaces of the doors and the holes that they leave open from the factory. There is a source of a bunch if noise right there. If you tap on the exterior of the door before the matt is put on it sounds like a drum. The difference is astounding.
I took it for a test drive and found that the doors sounded great but I could hear a source of more noise in the back seat. After taking all the back seats and hardware out I saw what equated to a large drum back there. I covered the entire rear cab facing the bed and then pulled out the floor matting under the seats to find the same issue. The carpet is pretty good at killing the sound due to its foal underlayment but this stuff was 1/8" thick of nothing.
One really bad source of noise was the cabin pressure vents behind the rear seats. I did seal those up but I am not reconsidering opening one of them up due to the high cabin pressure when the A/C is on even the low setting. On high I felt like I was in an airline with pressurization problems. Figure I could always get in the truck if a have a diving accident and need a pressure vessel
The difference is night and day. If your looking for a way to make your truck nice on long trips, This is the way. I will post before and after tests with a sound pressure level meter here soon. I will go for a test drive at the dealer with a stock unit on the same street, speed, and lane as I test mine. I can’t wait to see... or should I say hear the difference.
Adam
Check out the insulation installation in my rig pictures here:
http://www.turbodieselregister.com/...?&albumid=17479
[unquote]
Old Apr 13, 2005 | 04:00 PM
Forrest Nearing's Avatar
sound deadener = GOOD
Dynamat = EXPENSIVE!!!
use cheaper alternatives.
I've got tons of sound deadener in my truck. it's the only way to fly!
Forrest
Old Apr 13, 2005 | 04:49 PM
BigBlue's Avatar
Most people don't want to put 300 lbs of lead in their trucks.
Old Apr 13, 2005 | 07:16 PM
that's probably a slight exageration, but asphalt based sound deadener isn't exactly light...
but, I also got the lead sheet for free!
Forrest
Old Apr 15, 2005 | 07:04 AM
killfast1's Avatar
Yeah but being a Cummins you wont notice the weight.
samiam4
Dec 19, 2012 12:08 PM
dodgintrouble
21
Feb 21, 2009 01:30 PM
matego
Jan 1, 2008 11:24 PM
Red3quarter
Aug 13, 2007 09:34 PM
t-boe
Apr 23, 2007 08:21 PM
