Smarty VS Comp
Smarty VS Comp
Ok the post is about the (phatty said somethin about in one of his posts) a ETH truck turin 291 at the wheels with a smarty got me thinkin.
A edge drag comp only adds 90 HP to a HO truck right?Or for that matter any tap wire fuelin box right??
Well if that is true wouldn't the smarty be puttin down about as much horses at the Drag comp??
What I'm lookin for is some dyno pulls from 6 speed HOs with just a smarty, and then a drag comp.
I'm really thinkin that on a HO truck the smarty may be the ticket because I know the smarty fuels harder down low that drag comp on a SO truck but I've never rode in a HO truck with a smarty.
Does this sound right or is the drag comp still gonna be faster because it taps the pump and lets it pull longer?
I know the smarty will fuel as far as the comp just wonderin if it is fuelin as hard.
drag comp will still be faster, its designed to fuel more thru the rpm band to 3200. the smarty cant add nearly as much fuel without the wire tap, but the power is very usable down low with less throttle pressure to get the power.
Well thats what I was thinkin.
Really need to look at some dyno graphs and see where the power starts to fall off on the smarty.
This is more of a ,um I've got an idea will it work kinda thing.
Ok what about the comp and a smarty??
I would say that would over fuel the turbo, wouldn't it seein as the comp can rasie the EGTs pretty quick.
I'm gonna start with the comp and then it the VP lives (if not Hot rod pump) I'll probably go with injectors and turbo.
dodgediesel
07-27-2007 08:59 AM
CTD_Neil
02-23-2006 09:27 PM
hellotbone
07-12-2003 12:58 AM
hellotbone
18
05-16-2003 04:40 PM
