smarty tst stack
Old Feb 8, 2008 | 01:54 PM
blueboy16's Avatar
smarty tst stack
what are the best power levels to run with this stack?
Old Feb 8, 2008 | 03:56 PM
haloman's Avatar
Smarty 3 or 5 and TST 5-7.
Old Feb 8, 2008 | 05:53 PM
Mike D's Avatar
TST 5-7 is if you have a TST Comp. otherwise go #9 on the TST.
Old Feb 8, 2008 | 06:22 PM
Ph4tty's Avatar
Try it with the smarty on 9 and the tst comp on 3-4
Old Feb 8, 2008 | 06:52 PM
graphitecumnz's Avatar
I run Smarty SW#5 and my TSTCE on 5
Old Feb 11, 2008 | 08:53 AM
blueboy16's Avatar
alright thanx guys. so is it just too much to run them both all out?
Old Feb 11, 2008 | 09:01 AM
dzlfarmboy's Avatar
After multiple dyno runs My TST COMP made the most power on level 6 and the smarty only varied like 5hp between all the settings.
Brett
Old Feb 12, 2008 | 12:50 AM
blueboy16's Avatar
alight so 6 on the tst and what on the smarty? 9? ive been runnin tst4 smarty 9 which seems to work good but if you have dyno proof i would like to know what is better
Old Feb 12, 2008 | 07:27 AM
haloman's Avatar
6 on the TST and 3 on the smarty. That should dyno the best.
Old Feb 12, 2008 | 07:47 AM
dzlfarmboy's Avatar
Here some test we did with our tow truck......
Made lots of pulls on a Dynojet 248H today. All pulls were made in 6th gear, and all numbers are uncorrected. Runs were made as close to each other as possible, basically as fast as i could change the smarty program.
The truck was my 01.5 high output with 118k miles. Performance mods are as follows:
-Smarty
-MITUSA mechanical fuel pump
-MACH 1.2 injectors
-Southbend 3600 12CB
-5" MBRP exhaust
-BHAF with heat shield
-Program #3 (Fuel, boost fooling and timing) ------------------- 337/802
*(started here because this program was already loaded)
-Stock software (truck defueled because i had no boost fooling)- 234/613
-Program #0 (Half Power)-------------------------------------- 186/456
-Program #1 (Fuel Saver)------------------------------------- 339/810
-Program #2 (Only Fuel and Boost Fooling)--------------------- 324/765
-Program #4 ("Soft" Catcher no timing)----------------------- 330/788
-Program #5 ("Soft" Catcher + Timing)------------------------ 340/812
-Program #6 (Mild Catcher no timing)------------------------- 327/773
-Program #7 (Mild Catcher + Timing)-------------------------- 340/808
-Program #8 (CaTCHER no timing)----------------------------- 325/769
-Program #9 (CaTCHER + Timing)----------------------------- 342/808
-Program #3 (Fuel, boost fooling and timing)-------------------- 339/811
*(went back to first program tested to check consistency)
-Program #3 (Fuel, boost fooling and timing) ------------------- 345/816
*(only change from above run was swaping BHAF for a stage1 AFE intake)
Brett
Old Feb 13, 2008 | 03:26 PM
blueboy16's Avatar
alright thanks guy for all of your input it is very helpful
Topper
Mar 3, 2008 10:17 AM
LooseBoltsRob
17
Jun 10, 2007 08:52 PM
smoky beast
28
Oct 13, 2006 01:15 PM
cummnz4x4pwr
Jul 30, 2006 01:37 PM
mjpalmer
May 19, 2005 11:34 AM
