Smarty and little smoke?
Old May 23, 2011 | 04:56 PM
farmboy99's Avatar
I just put a smarty s-03 stacked with an edge ez and it barely smokes. It gave a ton of power but took away milage and smoke. Whats the best settings for these? I have a stock clutch but want the smoke.
Old May 23, 2011 | 06:24 PM
DIESELWRKS's Avatar
if you start raising the TQ values higher u will slip your clutch. the higher you go on the smarty and the values. you will hurt the clutch. but this is what I run on my set up daily
sw 9 uneven number cause the timing on the smarty is better than the timing on other boxes I have used. to much timing together is bad.. so in your case try sw 8.
the torque is set at #6
timing is set at #3
fuel duration is #3
but if you bog your engine down and go in the peddle you will make alot of smoke because your turbo wont be spooled and will be choking. but to each there own on excessive smoke.
watch your clutch.
and your stock turbo
looks like you should have plenty of fuel pressure.. also the smarty doesn't add alot of HP. its more of moving the Tq and pwer early. but works the best with injectors and a mild box.
Old May 24, 2011 | 05:45 AM
farmboy99's Avatar
timing is set at #3
fuel duration is #3
watch your clutch.
Ok Ill try that. Thanks
Maddog411
21
Feb 29, 2008 07:28 PM
TNLoneWolf
Oct 6, 2007 09:59 AM
JW3
Mar 15, 2006 08:23 PM
