smarty + edge comp help
Old Jun 4, 2009 | 06:03 PM
inlinekeith's Avatar
my friend has an 02 2500 ddp2 and (mach 4s not in yet), hot rod vp44, 64 trim turbo, full built suncoast trans, intake, exhaust, edge comp, and smarty my ques is 1st does the edge add timing and should I run timing on the smarty also what suggestions on settings do you recommend? Thanks
Old Jun 4, 2009 | 06:30 PM
scottsjeeprolet's Avatar
Only run the even tunes on the Smarty. Comp does the timing. Smarty doesn't on the even numbers.
Old Jun 4, 2009 | 07:06 PM
Thanks what would u run the injector duration at I need a crash course on the 2nd gen smarty
Old Jun 5, 2009 | 05:18 PM
Beast2B's Avatar
start with the default settings for whatever you want to use. change the other settings once you find a setting you like for power delivery.
Old Jun 5, 2009 | 05:20 PM
Beast2B's Avatar
i found it best to go to level 5 and drive it for a day or two. play with one setting for a few days and see how it changes, then play with the other setting. if you start adjusting all of the parameters at the same time you'll never know what each change does on YOUR truck!
patience, grasshopper!
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
