smarty coments
Old Feb 23, 2006 | 05:00 PM
  #61
jfpointer's Avatar
Originally Posted by Geico266
*** SMARTY UPDATE ***
After a no go on the 1st try Marcos & Bob went back to the drawing board and came solved the problem I had, and returned the Smarty. It works GREAT! Really points out my slipping tranny. Dave Goerend get's my truck next week for a full blown tranny & a 3 disc TC.
Life is good when Smarty is under the hood.
Marcos & Bob are top notch. Buy a Smarty with confidence, they will take care of you if you need help.
So what turned out to be the problem?
Old Feb 23, 2006 | 05:18 PM
  #62
Geico266's Avatar
My truck was built late 98, and the ECM version was "unrecognized". It is a "safety" feature built into the Smarty software as to not cause a problem with the stock ECM until the software is version is known. Marcos found out what the version was added it to the Smarty list of approved software. A very fast and simple fix, and ZERO down time for my truck.
Hopefully, Bob will help explain it better, but I think I'm close.
In any event, the Smarty works great now!
Buy with confidence, these guys are on the cutting edge of making our trucks RUN strong!
Old Feb 23, 2006 | 05:28 PM
  #63
hotdram's Avatar
I did. Now I just have to wait for it
This is me waiting on the front step watching for the brown truck:
~Rob
Old Feb 23, 2006 | 07:29 PM
  #64
Geico266's Avatar
~Rob
You'll be waiting a long time. They mail them. USPS.
Old Feb 23, 2006 | 07:31 PM
  #65
2500Ram's Avatar
Does anyone have or know what is a good tow number with the Smarty stock? I thought I read it has a tow haul mode but can't find that info. We have a ~7k TT we tow through the Rocky Mountains and would like more power.
Old Feb 23, 2006 | 07:51 PM
  #66
Ph4tty's Avatar
Anything above sw1 should be fine. Beyond that it is just a matter of how fast and hard the power comes on in regards to throttle input and I've read posts where people have towed with the top setting sw9
http://www.madselectronics.com/Smarty03.html
Old Feb 23, 2006 | 08:17 PM
  #67
CASMOKIN's Avatar
Well Ive been convinced. I will be ordering mine shortly. Thanks for all the great input everyone.
Tom
Old Feb 23, 2006 | 08:24 PM
  #68
phox_mulder's Avatar
I've scheduled time tomorrow for a call to Goerends, then I'll be calling Bob.
(might even have him slip a set of Don M's injectors into the box )
Smoke is rolling off my pants right now, that Tax Refund burning a hole in my pocket.
phox
Old Feb 23, 2006 | 08:26 PM
  #69
gcshooter's Avatar
Rob, don't feel all alone on the porch. I am waiting on brown truck also. I know mine will be on a brown truck. Hope to see it middle of next week. I hope you do to.
Old Feb 23, 2006 | 08:27 PM
  #70
hotdram's Avatar
Originally Posted by phox_mulder
Smoke is rolling off my pants right now...
phox
Sounds like that isn't the only place you will have smoke rolling from
(DonM's 1.6's are next on my list )
~Rob
Old Feb 23, 2006 | 10:13 PM
  #71
duallydave's Avatar
Talking
has any one used the smarty with bdxxx injectors?i have bdxxx 130hp injectors and a comp,i ordered my smarty earlier this week after reading so many comments on how it performs with a comp.cant wait to get it,are the bdxxx injectors comparable to the more common ones,i dont hear that many people using them.
Old Feb 24, 2006 | 08:26 AM
  #72
cditrani's Avatar
My truck is essentially stock (no power mods but the EZ, stock exhaust and intake), and I was blown away by #9. I can't even imagine what it'd be like adding a serious fueling box and big injectors.
I'm a very conservative mod'er; I've only changed things that I felt were really wrong from the factory. The Smarty makes the factory fuel map seem as wrong anything that ever was wrong...
Old Feb 24, 2006 | 08:38 AM
  #73
Mike D's Avatar
Good to hear! You're a good guy Geico266. You stuck with the problem till it was fixed, even if it wasn't the easiest thing to do at the time.
Old Feb 24, 2006 | 08:58 AM
  #74
HOHN's Avatar
Try some Mach 4s. They get along with Smarty quite well.
Then, if you are feeling ambitious, add a TST box
Old Feb 24, 2006 | 09:01 AM
  #75
HOHN's Avatar
Originally Posted by bamadzl
Fox128
I'm basically stock except for the Smarty and I think you would be ok without gauges unless maybe you tow heavy or often. I haven't noticed any significant change in EGT's.
Brad
Smarty with stock injectors cannot hurt your truck through overboosting. There's just not enough fuel to really hurt anything.
I'd still recommend gauges, but you could probably get by without boost and pyro. Still need FP.
In my case, I'm WAY overfueled for what I should have, so a pyro is a MUST HAVE. I could melt my engine without it if I was ignorant and foolish. I mean, MORE ignorant and foolish
