smarty ??
smarty ??
I was over at a guys house today and he wanted to put his smarty on my truck just to check for codes but when he pluged it into my port the smarty would not come on .We tried and tried but no worky but it would work fine on his truck does anyone have any ideas on this ?
I don't have the wiring diagrams for an 01... sorry. But it would not necessarily mess up something else. The OBD standard requires to supply 12V on Pin16 and ground on pin5
(Looking at the connector the upper row is 1-8 and the lower row is 9-16 from left to right)
See http://www.auterraweb.com/obdiipinout.html
HTH
AlpineRAM
HTH
AlpineRAM
HTH
AlpineRAM
HTH
AlpineRAM
smarty
Well I found that pin #16 was pushed out thru the back of the connector. So I checked it with a multimeter and I got 12.3 v so I think that was the problem . But now after fixing the pin back into the connector I lost current to pin #16 ,my radio , cigarette lighter and interior lights don't work .I checked all fuses and they were all ok . Any ideas guys I am pulling my hair out on this one .
OK, you blew a fuse while reinstalling the pin. I think this should be a fuse in the PDC under the hood. (But I could be wrong)
Look into the owners manual, there should be a fuse plan that shows you where the mirrors etc are connected.
HTH
AlpineRAM
HTH
AlpineRAM
AlpineRAM you where right it was a fuse it was the (IOD) fuse the one with that little plastic housing around it making it hard to get to on the left side of the dash .I was checking it with one of those fuse checker tools that lights up but it showed that the fuse was good .So after searching on the net last night I ran across some info at geno's garage web sight so I pulled the fuse and sure enough it was bad .New fuse and all is ok so thanks AlpineRAM and every one else for their help .
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
CTD_Neil
Feb 23, 2006 09:27 PM
