Small Schwitzer versus Dodgezilla
Old Jun 5, 2005 | 09:11 PM
RonA's Avatar
I bought a small Schwitzer a while back. It has a small compressor side(56 or 58). How do these compare to the 35/40 hybrids? I have a Dodgezilla/14 in my twin setup now and am wondering if it would be a waste of time or not to build a new hot pipe and try the Schwitzer.
Old Jun 6, 2005 | 12:00 PM
HOHN's Avatar
21 psi will support 350hp with a clean tailpipe, so I'd say that the smallish compressor isn't that big a deal.
IMHO, the turbine side is what needs attention on these trucks. If the Schwitzer has a better turbine side (more efficient, less back pressure) then I would expect it to outperform a Holset hybrid.
jlh
Old Jun 7, 2005 | 08:46 AM
RonA's Avatar
I guess there are not many who have tried these small S300 based turbos. Probably a good reason . I'll try something else.
Old Jun 7, 2005 | 08:57 AM
signature600's Avatar
I'd call HT Turbo and ask them...they do both Holsets and Schwitzers, so I think they could help!
Chris
Old Jun 7, 2005 | 09:27 AM
justinp20012500's Avatar
It has much more lag then a Hybrid.
It surges while towing if you are not running enough filter. The comp wheel has to be sized perfectly for the altitude/power level or it will surge.
This one has a 65 mm wheel, and a 14.77 dual port w/g housing.
Roman (RDLeader) is using one in a staged setup.
Justin
Old Jun 7, 2005 | 12:27 PM
PourinDiesel's Avatar
Fram?
Old Jun 7, 2005 | 01:06 PM
Originally posted by PourinDiesel
Fram?
Not mine...
I already gave the lecture.
Old Jun 7, 2005 | 01:19 PM
RonA's Avatar
The compressor wheel on this one is 56mm. That's almost as small as a stock hx35.
Old Jun 7, 2005 | 06:01 PM
Justin
Justin,
My B1 surges BAD when towing below 2000 (which is where the truck runs most of the time), so are you saying thet I don't have enough filter??
Could you explain more, possibly??
Thanks,
Chris
Old Jun 7, 2005 | 08:06 PM
Originally posted by signature600
Justin,
Thanks,
Chris
I built the above turbo for a friend. He is running a drag comp/superchip tuner stack along with a set of jammer 5's that flowed 55 lpm. (Regular jammer 5 flow 45-47)
When he was right at 1700 rpm's empty he could get it to surge. When towing it was even worse.
We changed the wheel from a 66 to a 65 and crap canned his super restrictive, very small filter. (He was running something that flowed less then a k&n in a stock air box.
After we did that the surge was almost nonexistent.
I see you are running a scotty with a hole. I would say you have plenty of filter. I am unsure as to what the B series turbos uses for wheels.
Old Jun 7, 2005 | 09:46 PM
kyle@ftlb's Avatar
Muted User
People dont just run the S-300's right out of the box from switzer, they always modify them with different wheels and housings because they surge in stock form. You want at least a 62MM Wheel. or dont bother with it.
Old Jun 8, 2005 | 07:29 AM
Cool, must just be more air going in than exhaust coming out at those RPM...either that, or I don't have a clue
Thanks,
Chris
CruisingRam
Jan 19, 2012 04:45 PM
signature600
Feb 4, 2005 08:58 AM
SmokinFive9 4x4
Nov 9, 2004 12:35 AM
gunracer1
Sep 27, 2004 11:25 PM
MoreSmoke
Jan 2, 2004 09:10 PM
