should upgrade?
Old Sep 27, 2005 | 09:12 PM
keithplacervill's Avatar
should upgrade?
on a 99 will the stock 12cm do good or bad on a motor dyno at 345hp or should he upgrade to ?
Old Sep 27, 2005 | 09:25 PM
BigBlue's Avatar
Is he pushing 345 to the wheels or the engine? I'm gonna assume he's got an EGT gauge pre turbo on it. If he's at 345 to the wheels with his stock HX35 then he's probably running pretty high egt's (1300*+) which is not good. An hx35/40 hybrid would work great if that's all the power he wants. If he wants more, then a piers HX40 would allow more room for power upgrades. Or better yet, a version of the B1 (I think there's 4 versions depending on what you want). Tell us what he's got done to his truck and we can give you some better advice.
Old Sep 27, 2005 | 09:28 PM
CTD_Neil's Avatar
I'm guessing he doesn't have an EGT gauge yet? The EGT's may get pretty hot with the 12cm housing. I could hit 1450 with the Banks crap and that's was with a 14cm housing at only 330 hp. Have him try it on the street and see hot it gets at WOT in high gear.
Old Sep 27, 2005 | 09:37 PM
sorry he has banks exhaust banks, exhaust brake,trans build like a tank, edge comp. trans,egt,boost pre turbo egt he say he sees 1100 getting on it hard 30 boost
Old Sep 27, 2005 | 09:48 PM
BigBlue's Avatar
If he's only seeing 1100* pre turbo then don't worry about the turbo. His EGT's are well within the safe limits.
Old Sep 27, 2005 | 09:52 PM
thanks so much i was just curious about high end res.
Old Sep 28, 2005 | 08:43 AM
CTD NUT's Avatar
FWIW, a 12cm HX35 boosting at only 30 psi @ 1100* egt is not making 345 RWHP....probably far from it. 345 RWHP is on the high side for a HX35 and boost and egt would have to be considerably higher with this turbo to make it happen......what fueling mods have been done?
Old Sep 28, 2005 | 09:46 AM
SHARPMACHINE's Avatar
One of the posts says that he has a comp.
Old Sep 28, 2005 | 11:17 AM
CTD NUT's Avatar
Whoops......I see that now.....gotta pay more attention sometimes!
NJTman
Jul 4, 2012 11:55 PM
LilBigd02
Feb 28, 2007 08:31 PM
redneck rebel
Jan 9, 2007 09:02 AM
schu
15
Oct 12, 2006 08:12 AM
Awall
Jul 31, 2006 11:43 AM
