Setting wastegate on twins
Old Nov 19, 2006 | 11:16 AM
aggiehorsepower's Avatar
I am fixing to put twins on my truck. HT3B on the bottom then the stock 35 on the top. I was wonderin how to set the stock wastegate on the stock 35?
Old Nov 19, 2006 | 11:52 AM
gman07's Avatar
IIRC, most people run the wastegate on the top at 22-25 psi.
Old Nov 19, 2006 | 12:28 PM
but how do u set the stock wastegate to that?
Old Nov 19, 2006 | 02:25 PM
Tate's Avatar
Usually with a boost elbow, or some manual boost controller. If 21 psi setting is needed, just use the stock elbow, since that is where the turbo wastegates normally.
Old Nov 19, 2006 | 02:47 PM
Jetpilot's Avatar
You might consider having the wastegate modified to flow more air.... Also have the snail crossdrilled. This is what we do for these types of turbos for twins.
Doug Smith
Old Nov 19, 2006 | 11:42 PM
95ram's Avatar
I agree with what Jetpilot said. Make the WG hole bigger. If you want to get real fancey you can make a differant flapper for the WG and make the hole realy big. I prefer to grind the center section divider down about 1.5" as aposed to drilling through the divider. I've seen to many cracks. I grind them down into a U.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
TxDiesel007
Nov 19, 2007 12:26 PM
Stock 02
28
Sep 24, 2006 11:09 AM
