S300:S400 twins
I've heard the turbine on the k31 is actually smaller than the one on your QD64. Sounds backwards to me
I guess thats why you got the new s400 =P
I went from an SPS62/K31 to a QD64/K31 a while back. Both setups work great. The 64 adds a bit to the top end performance and takes a tiny bit off the bottom end. Either way will tow just fine. But the 62 comes online a tiny bit sooner. The turbine on the k31 is larger than the 71mm turbine on the QD64. I tried my old SPS62 as a single. It was ok as long as you keep an eye on the egt's. No way I would stay into it for very long. There is no comparison power, or egt wise between running the SPS62 by itself and running it with the K31. I switched to the 64 to add a bit to the top and keep my boost numbers at 65psi max with my pump increase.
I just have a big concern if im making as much heat as I am now with stock injectors, stock DV's and not towing that the ps62/k31 wont be enough cooling for me and I really dont want to buy more stuff that dosent work. Since I cant weld do you know if anyone makes setup to hook my sps62 up to a s400?
Rip Rook at Sourceautomotive.com makes all the piping you would need I believe. If you advance your timing more it will help your EGTs btw.
Ron, how would you feel an S400 with 75mm inducer and 1.32 a/r turbine using an 88mm wheel do for street/strip?
That's a good point about the timing there Captain if you are stock that is a problem as you step things up! Ron so overall the best primary for both bottom end and top end charge in your opinion is a k31? How do you think the old Bht3b would work with my ss turbo? Unfortunately the cost is catching up to me and I have to start paring thing's should I just go with the s400 since they are relatively cheap?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=013
I think that would spool faster (or as fast) as a K31 and support about as much HP. Piping would be a little more involved but for the price it would be worth a sot IMO if you are on a limited budget...
does the s400 not cool as good as the k 31 towing at low rpms or is it just laggy? i just need something to keep me cool towing and racing and be a reliable 700 horse truck for all around use.
The 400 will cool better on top, but be slower to spool (laggy) and run hotter at low rpm.
I called that source place about pairing the s400 with a sps62. They have a kit that includes everything but the sps62. and of course its $$$$$$$ but he said it only cools on average like 200-300 degrees more then the single.. That dosent seem like its worth all the money and it deffintly dosent seem like it will cool those injectors if I put them in on top of everyone saying the trucks going to be super laggy.
