quick boost question
Old Oct 12, 2011 | 12:11 PM
DC199512V87's Avatar
in the process of working on my truck and was wondering what the stock boost elbow is good for? right now it sits at 25 psi but i want 35. do i need to order an aftermarket one (like tst sends with their plates) or can i make this stock one work? can mod it if thats what it takes.....i have access to tools and allen screws
Old Oct 13, 2011 | 04:08 AM
zthatzmanz28's Avatar
I believe it has to be changed? You can use a needle valve with or swap out for an elbow that has the set screw.
Old Oct 13, 2011 | 10:03 AM
infidel's Avatar
There is no stock boost elbow, only aftermarket.
You can buy an elbow on ebay for under $20
Old Oct 13, 2011 | 01:11 PM
HOHN's Avatar
Stock boost setting will be 20 or 21psi typically.
You have to modify the signal to the wastegate to raise this.
The proper way is with a boost controller. I bought mine from www.boostcontroller.com (no affiliation)
Justin
Old Oct 13, 2011 | 09:47 PM
well it was 23 psi before....now with no fuel plate it hits 34 so now i guess i dont need the elbow after all...although im still 99% sure it has one. o well, no biggie. thanks guys
Old Oct 14, 2011 | 01:25 AM
greasy's Avatar
I took mine off, just plugged the hole
I haven't hit 40 yet, but 35 isn't too hard to get.
I'll get a load on it and a good pull see if it goes too high, stock turbo don't wanna get 40 lbs on it
Old Oct 14, 2011 | 10:10 AM
infidel's Avatar
That's only for the electronically controlled 24 valves.
Won't work on the all mechanical 12 valve.
Just plugging the wastegate hose at the turbo works great as long as it keeps the boost under 35 psi.
Old Oct 14, 2011 | 12:06 PM
well like i said, looks like i have a boost elbow has a set screw and everything. i just don't like the idea off plugging it and no control. wouldn't want to go over 35psi on stock turbo....not worth the risk.
Old Oct 14, 2011 | 09:58 PM
Tate's Avatar
You're thinking of a boost fooler. Boost controller goes inline between the manifold signal and wastegate to delay opening of it. It'll work on anything with a wastegate.
cquestad
0
Jun 1, 2007 01:24 PM
berok
May 4, 2006 07:56 AM
HorseHauler
13
Mar 12, 2006 11:48 AM
Ramdriver15
Mar 9, 2006 05:54 PM
callum
Sep 26, 2004 06:34 PM
