Question For An Injector Guru....
Old Feb 29, 2004 | 03:41 AM
SilverDodge's Avatar
So, as my sig. says, i have twins and super mentals. I would like to increase my spool up and pull, so looking to change showerheads. I am a 01 ETH 6speed, 20 over head gasket (head was shaved 6 though) and a HX35/12 - HT3B/23 twin setup. I dont tow at all, my main goal is ultimate street performance. What is the largest EDM injector that i can safley go with?
Thanks!
~Darin
Old Feb 29, 2004 | 09:05 AM
Stamey's Avatar
I'd say you should contact Don M directly have have him make you up a custom set. I hear he will work with you to give you what you want, probably Mach 6's. When I get injectors that's where mine will come from.
Chris
Old Mar 1, 2004 | 11:38 AM
HOHN's Avatar
With those tight housings, there's NO WAY you could run a Mach 6-- not enough air. Even a Mach 5 would be a little warm.
I think Don would recommend a Mach 4 or 4.5ish. The 4's would be pretty safe EGT wise.
Consider also that the Mach injectors are a lot hairer in each stage than most honed injectors. A Mach 3 is about SuperMental level (only a lot less smoke).
A mach 4 would put you right near where a Mega Mental runs, only a LOT cleaner.
Not to mention is will spool those twins in a blink
Justin
doorguy
33
May 18, 2011 12:39 PM
justagoodolboy
Jan 16, 2009 07:32 PM
cwoodall
Sep 25, 2007 05:39 PM
Haulin_in_Dixie
15
Sep 6, 2005 06:08 AM
oscaroc
Apr 2, 2005 12:14 PM
