question for fass user's?
Old Jun 11, 2004 | 09:29 AM
j's Avatar
j
i installed my fass system yesterday and have a couple questions. first of all i seem to have a leak somewhere near/at the fuel tank suction. i cant tell if it is leaking or if it's just extra fuel from the original suction tube that is leaking out. i turned the fass on and pressurized the system. i dont see any leaking, but after i park the truck or sit in one place for a few minutes, there is a small spot of fuel on the ground. i cant see where it's coming from if i'm looking at the top of the tank. anyone else have this problem? ....2nd. i want to remove all the stock filter and pump assemblies, but what do i do with the sensors? like the water in fuel plug and fuel heater plug? do i just let them hang there?... thanks in advance.
Old Jun 11, 2004 | 10:51 AM
Olratlr's Avatar
fass users
Mine had a wet spot twice it was only fuel coming out of old Fuel line.
Old Jun 11, 2004 | 11:10 AM
GIT-R-DONE's Avatar
A few things to check. Make sure the filter is tight. Check at the "T" , to see if its leaking there.
Old Jun 11, 2004 | 03:37 PM
j's Avatar
j
i'm pretty sure it's fuel from the old line. it really started coming out when i opened the water drain on the stock filter assy. i'll keep an eye on it for the next couple days and see what happens. what a difference the fass makes though. it keeps right on pulling till it shifts and doesn't starve for fuel at higher revs. thanks for the insight on the leaks...... git-r-done i pm'd you
Old Jun 11, 2004 | 05:00 PM
MikeR's Avatar
Just tape-up the sensor connectors so the weather/water doesn't get on the terminals, and leave them. There's no where else to plug them into.
Old Jun 11, 2004 | 05:14 PM
rharveysr's Avatar
I also had a small leak I thought but it turned out to be the old line draining fuel. I need to cap it off with some type of tape so that it does not get dirt in it.
Rick
Old Jun 11, 2004 | 05:48 PM
graphitecumnz's Avatar
Just to reiterate what others have said, culprit is most likely the old fuel line... had a spot under my truck for a couple of days...
Old Jun 12, 2004 | 09:38 PM
j's Avatar
j
i narrowed it down to the old fuel line. i haven't had a leak/spot on the ground since yesterday. everything seems to be working great.
SOhappy
Oct 15, 2007 06:10 PM
mrw
Oct 29, 2006 10:47 PM
Begle1
Apr 9, 2006 08:55 PM
KatDiesel
Oct 10, 2002 03:54 PM
