Question for anyone with an ISSPRO fuel pressure guage
Theres a big rubber grommet on the drivers side firewall....probably 3.0" or so. I cut a slit in the rubber and ran all my lines and tubing through.
Be careful on the guage placement - the oil pressure guage in the pic covers the diagnostic port - which is ok on a 12V but you probably want to leave yours uncovered so you have access.
Are you installing a pyrometer and boost guage? If so, this is a good time to do it - its much less painful that way. If you arent doing the other guages, you should consider it.
Dr Evil,
Thanks a lot for all your help with this. I've been reading threads about fuel pressure gauges for the last couple a years on here, just finally got around to getting one myself.
Yeah, it'll fit next to the diagnostic port. I'd already looked at that since I have to access it for my Superchips tuner.
I've already got the pyrometer and boost gauge that came with the Banks kit. I did debate on just getting the whole Isspro kit from Vulcan and then selling the Banks gauges, but they're still working fine and I just didn't want to go through the hassle of redoing the whole thing.
ctd89-99 must have a "one in a million" gauge.
I can't recall ever hearing of an internal leak in a Isspro gauge before.
Mine hasn't leaked a drop in 9 years and 135,000 miles.
(and mine sits on top of my dash)
I have the Isspro 0-30psi fuel pressure gauge run into the cab without an isolator. I used rubber, diesel friendly, fuel line and connected it to the bleed port and gauge with barbs...after first removing the tire type valve with a tire valve removing tool.
I recommend using enough fuel hose so that you'll have enough to reach out the drivers door so you can bleed the hose by bumping the starter.
fullpull108
Oct 10, 2010 11:23 AM
DodgeRocks
Mar 23, 2010 09:56 PM
Shanajustin
0
Feb 14, 2008 08:42 PM
bigragu
Jan 24, 2006 11:16 AM
Dodgezilla
Mar 7, 2003 12:06 PM
