ISSPRO IV fuel pressure guage install question.
Old Mar 6, 2003 | 08:11 PM
Dodgezilla's Avatar
I'm planning on installing my new guage this weekend and it doesn't come with any instructions. It looks very simple except I'm not sure where on the fuel filter canister to connect it to. I also got the banjo bolts from Wildcat Diesel and am wondering if these will be easy to get to and change out. They also have no directions. I just like to be prepared before i start a project.
Old Mar 6, 2003 | 08:31 PM
Dodgezilla's Avatar
Re:ISSPRO IV fuel pressure guage install question.
One more question.. When I remove the A-pillar will I have easy access to run my wiring under the dash and out to the engine compartment?<br>Thanks in advance for all the help....
Old Mar 6, 2003 | 08:36 PM
Bulldozer's Avatar
I just put my Isspro fuel gauge in that I got from Rod yesterday.I put it on the bottom of canister like Rod said to. Worked slick. I did drill a hole in my firewall and ran my fuel line and pyro wire through and now I have a loud engine noise in cab. I tried to seal the hole up It all most sounds like air in the fuel system or injector.But I think Its just because I pulled the insulation back a little and drilled an oversized hole. I cracked the fuel filter cap to day and bled it,still noisey.Other than that It took about 5min to install. Jake
Old Mar 6, 2003 | 08:46 PM
Racer57's Avatar
Like Bulldozer said. From the bottom of the fuel filter. Use the major grommet and fuel line will go thru NP. I ran my SS braided line thru there also along with a lot of other stuff, 2HIlow, Comp wiring, EGT, boost etc. You will have to make additional slices in it but so what. Noise is from that area is not my problem as I have a Scotty II cowl opening and can only hear my turbo.
Old Mar 6, 2003 | 08:57 PM
Shovelhead's Avatar
Administrator / Scooter Bum
This is a pic of my '99 mechanical guage install.<br>The pic shows the pick-up on the pre-filter plug in the top of the filter housing. Use the one closest to the front for after-filter pressure.<br><br>Isspro FP guage<br><br>The needle valve is to restrict the flow to the guage to prevent &quot;Buzzing&quot; in the guage. The pressure still reads fine. <br>I installed the guage &amp; line with the needle valve in place.<br>To set it up with the needle valve, just close off the valve completely, start the truck and have someone watch the guage, slowly open the valve, stop turning as soon as the pressure reads normal. Shut down to verify that the pressure bleeds off, start again to ensure pressure reads correctly. <br>Presto.....you now can drive knowing that your fuel pressure is good and your lift pump is supplying plently of fresh cool fuel to keep your injection pump happy. ;D
Old Mar 7, 2003 | 06:44 AM
Dodgezilla's Avatar
Thanks guys. I think I will be hooking up the guage post-filter as I think my new filter is too restrictive. I'm gonna buy a NAPA filter and check the difference and will post the results here. Is there any advantage to hooking the guage up on top versus below the canister? If not, why wouldn't I do the easy hookup on top???
Old Mar 7, 2003 | 08:23 AM
Shovelhead's Avatar
The 99's had the guage hook-up on top, and a &quot;Bottom-Load&quot; design canister.
They changed the filter canister design in 2000 so their filter is a 'Top-Load&quot; and their pick-up point is underneath.
Old Mar 7, 2003 | 11:30 AM
Dodgezilla's Avatar
Aha!! I understand. Shovelhead, you are just a Veritable Plethora of information!! Thanks for all your input to my posts. So, when can I drop my truck off for you to install all this stuff for me??
Old Mar 7, 2003 | 11:57 AM
Shovelhead's Avatar
;D<br>I'm in Arlington, Va. <br>My Daughter lives in &quot;South DC&quot; too.<br>We have a BOMBing party/Food Fest in Joppa Md next weekend. Should be lotsa wrenching going on too.<br>Come on up. <br><br>Ed
Old Mar 7, 2003 | 12:04 PM
Dodgezilla's Avatar
What exactly is happening in Joppa next weekend? I wish it was this weekend as the wife and daughter are out of town. That's why I'll be plugging away on the truck. I work in Alexandria on Edsall Road..
Old Mar 7, 2003 | 12:06 PM
Shovelhead's Avatar
Here's the link to the thread:<br>https://www.dieseltruckresource.com/...threadid=11065
jcmoyer2004
Mar 18, 2011 12:16 AM
fullpull108
Oct 10, 2010 11:23 AM
DodgeRocks
Mar 23, 2010 09:56 PM
OldDodgeOwner
19
Jan 21, 2009 01:58 AM
bigragu
Jan 24, 2006 11:16 AM
