Quadzilla Monitor Trans Temp Send Hookup???
Hey I been installing the Quadzilla Monitor today and when I removed the nut and washers from the trans send unit they came off in this order. (nut,lockwasher,flat metal washer,fiber type washer,wire,then theres a plastic piece left on the sending unit) Question is do I hook this back up like they were? Seems like wire is going to be isolated being between plastic and fibre washer. Any help asap would be appreciated, gona get dark on me
I have to visualize, but the plastic washer typically goes against the body of the sender. Then a flat washer, ring terminal, fiber washer, lock washer, nut.
At least if I am thinking right. I don't have a sample in front of me.
Dave
Dave
When I installed mine from sender to tip of screw post it went: plastic washer, fiber washer, ring terminal from wire, flat washer, lock washer, nut. Pretty sure it shows a good example of it in the adrenaline installation manual.
Shawn
Shawn
SilverRam3500
Feb 16, 2008 11:21 PM
DetroitDiesel71
Nov 22, 2005 08:50 AM
RamRat
Apr 3, 2004 12:53 PM
