Where to hookup Trans Temp Sensor?
Old Feb 16, 2008 | 10:27 AM
SilverRam3500's Avatar
Finally getting all my gauges on the truck!
If any can help.....
Where do I hook up the trans temp sensor on the transmission.
I have a '99 3500 auto CTD.
Is it on the driver side or passenger side.
It just seems to have a few too many places to plug into but I dont want to plug into the wrong place.
Also does the trans fluid come out when I unsrew the place of mount the sensor into?
Old Feb 16, 2008 | 11:23 AM
high bid's Avatar
I believe the best place is the hot line to the cooler however Quad states the test port on the pass side of the tranny. After experience and readings I would go w/the hot line to ensure best results.
Old Feb 16, 2008 | 11:59 AM
The sending unit I have is not an inline unit. Its a Vulcan kit Diprocol.
It must bolt on to the housing somewhere. I have 3 different size port fittings thiough just in case.
Does anyone know where on the housing it screws on to??
Old Feb 16, 2008 | 03:26 PM
MAX340's Avatar
Do not use ay of the test ports. These may give a false reading on the guage. Also, depending on depth of the sensor and port used, you may obstruct a servo.
Best place for a trans temp sensor is in the line to the cooler. Next is the pan.
Old Feb 16, 2008 | 07:31 PM
OK Max. Where do I get an inline to put sensor on. I've seen a brass in line fitting with a tap threaded hole on here somewhere.
But where can this fitting be bought. Napa? or Advance?
I think the in line on the hose is the way to go??!!On the hot line of course.
Old Feb 16, 2008 | 07:44 PM
99globalwarmer's Avatar
in the hot line is the best
http://www.dieselmanor.com/dm_products/DM-CLG2.asp
or try garrett at puredieselpower.com
Old Feb 16, 2008 | 08:02 PM
WestTN's Avatar
All the data forheat related oil degradation developed over the years in industrial equipment oil is related to sump temperature.
Old Feb 16, 2008 | 11:21 PM
MAX340's Avatar
Brass fittings can be had at almost any parts place. Have to find a spot to install, then take what you have for the sensor and go from there.
progrower
Oct 31, 2009 02:50 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
mowin4dodge
Mar 17, 2008 10:08 AM
DetroitDiesel71
Nov 22, 2005 08:50 AM
