Trans Temp Hookup
Old Oct 29, 2009 | 04:33 PM
progrower's Avatar
Trans Temp Hookup
Dose anyone know if the transcender tempature adapter from diesel manor is a good way to hook up a trans temp gauge?http://dieselmanor.com/dm_products/DM-TRS.asp
Old Oct 30, 2009 | 08:08 AM
high bid's Avatar
I used the test port on the pass side of the tranny. Some say to get a more accurate reading to "tap" directly into the pan. Sorry, but I have not had exp w/that adapter.
Old Oct 31, 2009 | 11:47 AM
progrower's Avatar
Bump. Any one have any exp. with the trandcender?
Old Oct 31, 2009 | 02:50 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Watch using the test port.
Some have installed the sender too deep, and have a created a problem blocking fluid flow.
Also, the temp will not read as high as it might actually be. (same trouble with the 'pan' installations)
The most accurate 'hot' reading is where the hot fluid comes out of the trans heading for the heat Exchanger.
The 'adapter' could work, but it seems the readings might be off with that chunk of aluminum possibly in the airflow.....still better than other options.
The older Ram trans 'hot' line sold by the dealer had a temp sender port manufactured into the line.
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
mowin4dodge
Mar 17, 2008 10:08 AM
SilverRam3500
Feb 16, 2008 11:21 PM
DetroitDiesel71
Nov 22, 2005 08:50 AM
